432 Big Block F1X Procharger #2732203
01/11/20 05:54 PM
01/11/20 05:54 PM
Sidney,Ohio
challenger1320 Offline OP
Sidney,Ohio
Dyno'd Whreatcrafts 432 BBM today made 1608 hp 1055 hp at 8000 rpm still making power and torque but didn't want to go any higher F1x12 Procharger 440-1 heads.
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2732207
01/11/20 05:58 PM
01/11/20 05:58 PM
Sidney,Ohio
Sidney,Ohio
All off the shelf parts
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2732218
01/11/20 06:49 PM
01/11/20 06:49 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
That's impressive. What block?
Re: 432 Big Block F1X Procharger [Re: camastomcat] #2732221
01/11/20 06:53 PM
01/11/20 06:53 PM
Sidney,Ohio
Sidney,Ohio
Indy low deck solid
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2732253
01/11/20 08:39 PM
01/11/20 08:39 PM
New York
polyspheric Offline
polyspheric  Offline
New York
What psi?
What prep to the deck?
Fuel?
Spark?
Thanks!
Boffin Emeritus
Re: 432 Big Block F1X Procharger [Re: polyspheric] #2732295
01/11/20 11:09 PM
01/11/20 11:09 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Almost as good as his Predator smile Do you work at Kammer?
Re: 432 Big Block F1X Procharger [Re: Al_Alguire] #2732385
01/12/20 09:39 AM
01/12/20 09:39 AM
Sidney,Ohio
Sidney,Ohio
Just a friend of chris
20 psi
Alcohol
22 degs timing
Not sure on the deck prep.
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2732391
01/12/20 10:20 AM
01/12/20 10:20 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Great post! There aren't enough of these high end posts IMO. It sounds like a good combo.
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2732395
01/12/20 10:50 AM
01/12/20 10:50 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
C&S carb with solenoid floats?
Re: 432 Big Block F1X Procharger [Re: Clanton] #2732415
01/12/20 12:10 PM
01/12/20 12:10 PM
Sidney,Ohio
Sidney,Ohio
APD Carb
Going in 1800 lbs dragster. For anyone that went to the PRI show it was in Indys booth
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2732456
01/12/20 02:08 PM
01/12/20 02:08 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
There has been a black dragster going out to Norwalk for some time,same blower but not your people.I will enjoy seeing another out there.
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2732482
01/12/20 03:35 PM
01/12/20 03:35 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Impressive for 20 psi.
Boffin Emeritus
Re: 432 Big Block F1X Procharger [Re: polyspheric] #2732526
01/12/20 06:13 PM
01/12/20 06:13 PM
Sidney,Ohio
Sidney,Ohio
We are going to build a 477 or 508 SR headed F1X12 next.
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2732539
01/12/20 07:41 PM
01/12/20 07:41 PM
Aren't those results kind of weak with a solid race block?
Re: 432 Big Block F1X Procharger [Re: Cab_Burge] #2732560
01/12/20 08:18 PM
01/12/20 08:18 PM
Casper, WY
W
Wax Offline
Wax  Offline
W
Casper, WY
Maybe they can get it in the dragster and have it at MATS in March.
Re: 432 Big Block F1X Procharger [Re: Cab_Burge] #2732572
01/12/20 08:59 PM
01/12/20 08:59 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I think 1608 on a 432@8000 is pretty impressive Cab. I think the 1055 was meant to be torque unless I'm wrong........
Re: 432 Big Block F1X Procharger [Re: camastomcat] #2732605
01/12/20 11:15 PM
01/12/20 11:15 PM
Sidney,Ohio
Sidney,Ohio
Yes 1055 was torque and it will be at the mats
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2732745
01/13/20 04:53 PM
01/13/20 04:53 PM
Not knowing what CFM the carb is has a lot to do with my thinking it was not making a lot of power, what CFM is it?
The smallest restriction on the intake side of air and fuel will be the limiting factor on power and fuel and air flow work
I've never built or race a motor with a blow through carb with either a centrifugal supercharger or turbos, my only blower experience is with pump gas roots blowers on 4 different motors, 3 motors with carbs and one with EFI shruggy None of them made over 2.0 HP per C.I. either, let alone 3.+ HP per C.I. up bow
I am probably to use to hearing guys racing heads up with turbos and procharger on methanol making 6.+ HP per C.I. with a lot more boost blush
Re: 432 Big Block F1X Procharger [Re: Cab_Burge] #2733018
01/14/20 04:10 PM
01/14/20 04:10 PM
Sidney,Ohio
Sidney,Ohio
3.7 hp per inch with the F1 is pretty good
1150 APD
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2733311
01/15/20 11:42 AM
01/15/20 11:42 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
That is very cool. I have been starting to plan a small cube power adder deal somewhere in the 400ish cube range. 3.anything per cube is unicorn numbers in my world. Awesome job. Do you know any specs on the piston/rings? I am curious what it takes to stand up to that kind of PSI.
