Window lift bracket rivet install?
#2730536
01/06/20 01:14 PM
01/06/20 01:14 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
Any tricks? Sure dont want to break the glass.........
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Window lift bracket rivet install?
[Re: burdar]
#2730553
01/06/20 02:28 PM
01/06/20 02:28 PM
JMCFAN
New Mexico
The lift bracket rivet is just plastic right? The center of the rivet pops out so the "fingers" can push through the hole in the glass. Once the center of the rivet is installed, your done.
I guess I should ask what vehicle your working on. My 68 Dart uses 1 plastic rivet for the lift bracket. My 73 Challenger uses a different setup. 70 RR. One pin in lift bracket. So when the fingers are through you push the center pin in correct?
[Re: burdar]
#2730566
01/06/20 03:36 PM
01/06/20 03:36 PM
JMCFAN
New Mexico
Got it! Thanks! Now the fun part....install in the doors......
