Window lift bracket rivet install? #2730536
01/06/20 01:14 PM
01/06/20 01:14 PM
New Mexico
JMCFAN Online content OP
JMCFAN  Online Content OP
New Mexico
Any tricks? Sure dont want to break the glass.........
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Window lift bracket rivet install? [Re: JMCFAN] #2730552
01/06/20 02:23 PM
01/06/20 02:23 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The lift bracket rivet is just plastic right? The center of the rivet pops out so the "fingers" can push through the hole in the glass. Once the center of the rivet is installed, your done.
I guess I should ask what vehicle your working on. My 68 Dart uses 1 plastic rivet for the lift bracket. My 73 Challenger uses a different setup.
Re: Window lift bracket rivet install? [Re: burdar] #2730553
01/06/20 02:28 PM
01/06/20 02:28 PM
New Mexico
New Mexico
70 RR. One pin in lift bracket. So when the fingers are through you push the center pin in correct?
Re: Window lift bracket rivet install? [Re: JMCFAN] #2730557
01/06/20 03:01 PM
01/06/20 03:01 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Yes, once the fingers are in, you push in the center pin.
Re: Window lift bracket rivet install? [Re: burdar] #2730566
01/06/20 03:36 PM
01/06/20 03:36 PM
New Mexico
New Mexico
Got it! Thanks! Now the fun part....install in the doors...... whiney
