I have a 1986 dodge d150 that originally had the lean burn computer. I removed it and installed an ecu and fitech fuel injection.
where is the best place to feed from for the run side of the ballast resistor? that is the only wire I have left. a diagram I found said to run from blue main ignition wire, but if I do that the starter will not turn off.
