Jeep 5.9 cam kit. #2729327
01/02/20 01:22 PM
01/02/20 01:22 PM
Iceland
N
NinerJeep Offline OP
N
Iceland
Hello. New here. Have 1998 Jeep GC 5.9 magnum. only has 100.677 miles on it. Stock. Currently have 8.8 rear axle ready if my D44A snaps. I know my trans is weak. 46RE. But i'm looking at WHIPLASH PREMIUM CAM KIT. It includes.
SMC1326AL Whiplash Camshaft
HUG5001 Lifter Set
HUG1110 Spring Set
HUG6440 Timing Chain & Gear Set
HUG22041 Distributor Shaft Collar.
My goal is 300/310 crank. I have 52 mm tb on the way + Spectre LoPro hat.
Is this set good my goal? My truck will be driven during summer only and used for streets.
Re: Jeep 5.9 cam kit. [Re: NinerJeep] #2729336
01/02/20 01:49 PM
01/02/20 01:49 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Your computer isn't going to like it.
Your power brakes aren't going to like it. To quote Hughes "Your vacuum should be in the 9"-11" range using this cam" power brakes like to see 17" minimum and you won't even be close.
Your pushrods will be too short, it's a flat tappet cam and your 5.9 has a roller cam in it now.
Re: Jeep 5.9 cam kit. [Re: NinerJeep] #2729344
01/02/20 02:03 PM
01/02/20 02:03 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
You might want to look at the hughes steamroller cam for the magnum, or similar cam from comp, headers, slight internal intake mods, aluminum plate kit hughes sells for the intake, and headers. Do not change to a single plain crosswind or edelbrock intake in a truck, you will hate it.
Re: Jeep 5.9 cam kit. [Re: 4406bbl] #2729354
01/02/20 02:26 PM
01/02/20 02:26 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
You also need to change valve springs, AND the stock heads will not take a lot of lift, like .480 comes to mind or you get retainer to guide boss and valve seal problems. Call Dave and ask, been a while since I messed with stock heads
Re: Jeep 5.9 cam kit. [Re: Sniper] #2729364
01/02/20 03:13 PM
01/02/20 03:13 PM
Iceland
N
N
Iceland
Hughes replied exactly at same time as you and said this wouldn't work either. They are gonna help me put something together.
Re: Jeep 5.9 cam kit. [Re: 4406bbl] #2729367
01/02/20 03:17 PM
01/02/20 03:17 PM
Iceland
N
N
Iceland
Hughes are helping putting together mildy build😀. Been thinking also new intake. But my budget is around 1100$
Re: Jeep 5.9 cam kit. [Re: NinerJeep] #2729391
01/02/20 04:41 PM
01/02/20 04:41 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
For your build I'd keep the Beer Keg manifold but get Hughes's bottom plate.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
