11" rear drum adjusters #2729034
01/01/20 03:55 PM
01/01/20 03:55 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I have a set of 11" drums with no adjusters. I have the rebuild hardware that has the adjusters.
Will I be able to use the automatic adjusters?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 11" rear drum adjusters [Re: cdstl] #2729044
01/01/20 04:12 PM
01/01/20 04:12 PM
The major visual difference between the stock non self adjusting and self adjusting is the size of teeth on them, the self adjusting are a lot smaller with a lot more of them on them,I've use the self adjusting on my drag cars with the rest of tat hardware taken off, the smaller teeth make it a little harder to adjust properly to the exact amount of width on the shoes work You need to be patient and count the strokes on the brake wrench when turning the adjuster to get them exactly the same on both sides.
You can use a large pair of outside brake calipers to do the adjusting with the brake drums off work I do up
Re: 11" rear drum adjusters [Re: cdstl] #2729047
01/01/20 04:15 PM
01/01/20 04:15 PM
New York
rarefish Offline
rarefish  Offline
New York
You can convert the 11" drums from manual adjusters to self adjusters. Just buy all of the self adjuster hardware.
I did that on my 68 Charger a few years ago.
Re: 11" rear drum adjusters [Re: rarefish] #2729147
01/01/20 09:17 PM
01/01/20 09:17 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I figured as much, but I wanted to check.
