92 Colt Update (Injector issue): Mits ECU-Bad Caps-Pics #272885
03/31/09 08:23 PM
03/31/09 08:23 PM
Louisville, KY
Allan_G Offline OP
Allan_G  Offline OP
Louisville, KY
Original post here: https://board.moparts.org/ubbthreads/show...e=3#Post5116478
Thanks to some good leads, I discovered my Mitsubishi-built Colt's ECU has been internally damaged by a leaking capacitor. In my research on this subject, I found out that many Chrysler vehicles have been plagued by this issue, including the Dodge Stealth. Some of my info came from Stealth/3000GT forums and sites, in fact. Here's one: http://www.stealth316.com/2-ecmremoval.htm
Although the exact years affected aren't written in stone, it appears that we're talking late-80's to early- or mid-90's. I'm passing this along in case it helps others track down any strange problems, including intermittent driveability issues.
I just ordered some caps for my ECU today, the obvious bad one plus 3 others as a precaution - caps are cheap! I have some board repair to do because of the corrosion damage, but hopefully this will take care of the injector problem. I'll post a few pics here. First one shows the offending cap at center. Orientation: left side is "up" in vehicle, so the leaking electrolyte ran to the right in picture ("down").
(FKA Racer Al back in 2000...)
Re: 92 Colt Update (Injector issue): Mits ECU-Bad Caps-Pics [Re: Allan_G] #272886
03/31/09 08:26 PM
03/31/09 08:26 PM
Louisville, KY
Allan_G Offline OP
Allan_G  Offline OP
Louisville, KY
Missed attachment on last post
Re: 92 Colt Update (Injector issue): Mits ECU-Bad Caps-Pics [Re: Allan_G] #272887
03/31/09 08:30 PM
03/31/09 08:30 PM
Louisville, KY
Allan_G Offline OP
Allan_G  Offline OP
Louisville, KY
More corrosion further to right, where ECU connector pins meet PCB.
Re: 92 Colt Update (Injector issue): Mits ECU-Bad Caps-Pics [Re: Allan_G] #272888
03/31/09 08:33 PM
03/31/09 08:33 PM
Louisville, KY
Allan_G Offline OP
Allan_G  Offline OP
Louisville, KY
Bad cap and location where removed.
Re: 92 Colt Update (Injector issue): Mits ECU-Bad Caps-Pics [Re: Allan_G] #272889
03/31/09 08:42 PM
03/31/09 08:42 PM
Louisville, KY
Allan_G Offline OP
Allan_G  Offline OP
Louisville, KY
Better view of corrosion after removing 2 of the bright green caps seen in previous pic. (Had to remove to get to PCB for cleaning - the juice ran right around/ underneath them.) Black devices mounted to heatsink in background are injector driver transistors. Note the corrosion at their legs.
Re: 92 Colt Update (Injector issue): Mits ECU-Bad Caps-Pics [Re: Allan_G] #272890
03/31/09 08:49 PM
03/31/09 08:49 PM
Louisville, KY
Allan_G Offline OP
Allan_G  Offline OP
Louisville, KY
Better view of corrosion at connector pins after removing heat sink. Nasty!
