4 speed guy
#2726321
12/23/19 08:31 AM
12/23/19 08:31 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
Doz NHRA Require a reverse lock out lever on your shifter ???
Re: 4 speed guy
[Re: RAY1969CARS]
#2726375
12/23/19 01:01 PM
12/23/19 01:01 PM
Posts: 4,457 Washington
madscientist
Washington
The NHRA doesn't require a lock out for a stick. That shifter you have is the Super Shifter III and they don't make it any more. A very good shifter.
Re: 4 speed guy
[Re: madscientist]
#2728773
12/31/19 11:28 PM
12/31/19 11:28 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
The NHRA doesn't require a lock out for a stick. That shifter you have is the Super Shifter III and they don't make it any more. A very good shifter. That bracket is a nice piece. Moves the shifter up and towards the driver. I have the same set up in my 65
Re: 4 speed guy
[Re: NTOLERANCE]
#2729544
01/03/20 01:14 AM
01/03/20 01:14 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
So, is that your shifter? is your question if NHRA doesn't require one you would want to not have a reverse lock out on your shifter? As stated above, the Hurst super shifter 2 is a very good shifter. No need to spend money on a in line .
