So what is it?
#2728654
12/31/19 08:09 PM
12/31/19 08:09 PM
Posts: 3,656 The Historic Hudson Valley
MONC
Anyone know what this thing is? Don't have any other pictures of it. Looks like some kind of tool or things to hang on, like maybe a ladder??
Mopar Or No Car
Re: So what is it?
[Re: Alaskan_TA]
#2728672
12/31/19 08:53 PM
12/31/19 08:53 PM
MONC
Lineman ladder hook.
To the right appears to be a bottle cap press. Ah, you da man Barry ! ( as usual And would that be your right ?? You will get your 'prize' at Carlisle in July ..
Mopar Or No Car
Re: So what is it?
[Re: MONC]
#2729549
01/03/20 02:55 AM
01/03/20 02:55 AM
Posts: 43,129 Bend,OR USA
Cab_Burge
That is one of the several attachments used on "lay op sticks" used in telephone work on outside plant, wires, trees and so on. I had and used one for many years doing telephone line work and telephone installations work We had tree trimmers operated by rope, tree saw and several other attachment to make our work easier and faster by doing some of it from the ground The sticks where right at 60 inches long, male and female ends so you could use one, two, three or four by assembling them hook together to reach up to 30 ft. or so. Ours where all galvanized, no paint. That is the first one I've seen painted I can't remember the proper name of that tool now, it has been more than 35 yrs since using one
Re: So what is it?
[Re: moparx]
#2729642
01/03/20 01:08 PM
01/03/20 01:08 PM
Posts: 1,701 central il.
second 70
central il.
i've always called those pike poles. don't really know where that name came from. Pole pikes have a spike on the end of them that you stuck in the side of a pole to move it and hold it straight until you get it tamped in. Most all trucks have pole claws to hold the poles now but you can't always use the truck and when using a crane we use them to push the pole against the side of the boom so you can use the crane to straighten the pole. https://www.hubbell.com/hubbellpowe...t-Assist-Tool/Pike-Pole-2-X-18/p/1648788
Re: So what is it?
[Re: second 70]
#2729669
01/03/20 02:40 PM
01/03/20 02:40 PM
Posts: 19,366 north of coder
moparx
i've always called those pike poles. don't really know where that name came from. Pole pikes have a spike on the end of them that you stuck in the side of a pole to move it and hold it straight until you get it tamped in. Most all trucks have pole claws to hold the poles now but you can't always use the truck and when using a crane we use them to push the pole against the side of the boom so you can use the crane to straighten the pole. https://www.hubbell.com/hubbellpowe...t-Assist-Tool/Pike-Pole-2-X-18/p/1648788 back when i was a volunteer fireman [i finally remembered/cleared the cobwebs from the back of the old/tired memory bank ] a "few" days ago, we used a multi pronged tip like was originally shown [with wooden handle of course] to poke and rip/pull/push burning walls and other obstacles/debris. we called those pike poles at the time. they did not have a single pointed tip as shown in the last posted pic, so we may have been calling them the wrong name. they definitely looked like the lineman tip.
Re: So what is it?
[Re: 360view]
#2729691
01/03/20 03:39 PM
01/03/20 03:39 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
