U joints #2727735
12/28/19 03:10 PM
12/28/19 03:10 PM
USA
K
Kippy Offline OP
Kippy  Offline OP
K
USA
Ive changed so many u joints and never had a issue until today. My u joint was tough coming out and what I found was the driveshaft yoke bores with some small nicks. I took a Dremel with a abrasive on a drum holder and lightly cleaned up the bores. I guess I got carried away and now the U joint caps slide right in. With the clips installed, I do not feel any play but im concerned the yoke is ruined and I need a new one. It was a combination U joint, so I was just thinking to get the bigger yoke installed anyway. What are your thoughts? Thanks
Re: U joints [Re: Kippy] #2727794
12/28/19 06:13 PM
12/28/19 06:13 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Time for a new yoke
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: U joints [Re: W.I.N. Racing] #2727804
12/28/19 06:51 PM
12/28/19 06:51 PM
USA
K
Kippy Offline OP
Kippy  Offline OP
K
USA
Originally Posted by W.I.N. racing
Time for a new yoke
. Yes and thanks. I also think the driveshaft is to short. I swaped out my 8 1/4 and installed a 8 3/4. I measured as per the driveshaft web site said and will be paying them a visit Monday....Appreciate the reply
Re: U joints [Re: W.I.N. Racing] #2727811
12/28/19 07:30 PM
12/28/19 07:30 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Time for a new yoke
You could try several different things but the correct fix is stated above twocents beer
