Bouncing speedometer needle
#2727058
12/26/19 01:37 PM
12/26/19 01:37 PM
Posts: 1,487 STL
cdstl
STL
1972 Standard dash E body.
As far as I know it has the speedo cable that came with the car. It is well lubricated with the graphite speedo lube that comes in a tube.
It's been to Instrument Specialties 2 times and the speedometer checks out as good.
I've had this problem with an AUTO trans and now with the MANUAL trans. I've also had 2 DIFFERENT speedo gears in there when I changed the rear end gears.
Tom at Instrument Specialties suggested that I trim 1/16" off of the end that goes into the speedo. I have 2 spare speedo cables that I will probably experiment with instead of grinding on the one from the car.
Have you guys had to trim the speedo cable and what was the result?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Bouncing speedometer needle
[Re: cdstl]
#2727111
12/26/19 04:24 PM
12/26/19 04:24 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Some replacement cables are made extra long and you trim to fit. If the cable is slightly too long and bottoms out in the speedo It could cause the cable to bind and whip around inside the housing. Also take a look at the entire cable housing. If it is melted or bent too sharp It can/will bounce. Try rerouting the cable to make the bends as gradual as possible (especially at the speedo end) while keeping as far from exhaust pipes as possible underneath.
[Re: GomangoCuda]
#2727119
12/26/19 04:53 PM
12/26/19 04:53 PM
Posts: 1,487 STL
cdstl
STL
Thanks,
This seems to be an on going problem with these cars. I do have a spot on the outside of the cable that is showing the metal cords, but does not seem to have been burned. I cleaned the inside well, blew it out and then coated everything with PB graphite spray. I trimmed a little off of each end and put a dab of grease under the ferule that is on the speedometer end.
We'll see.
[Re: Sniper]
#2727145
12/26/19 05:55 PM
12/26/19 05:55 PM
Posts: 1,487 STL
cdstl
STL
Since it's such a PITA to change the cable, I ordered a $38 one shipped from Ehrenberg. I did that 2 hours ago and when I just checked it showed that it was shipped. I've bought a few things from him and have never been disappointed. His stuff isn't any more special than the same thing somewhere else, but he's a Mopar guy and I figured what the heck.
I'll check this cable vs. mine and trim it to match if it's long and then probably use it.
[Re: cdstl]
#2727169
12/26/19 06:54 PM
12/26/19 06:54 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Just to add...
Make sure your block to firewall ground strap is real good. If not the speedo sheath becomes a ground and that is NOT a good thing.
I did have a too long center that I made and it bounced the speedo too. Cut it down and that fixed it.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: convx4]
#2727453
12/27/19 06:00 PM
12/27/19 06:00 PM
Posts: 15,907 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'm confused. Aren't the cables usually pre-lubed with a special grease, and not a dry lube like graphite. Aftermarket ones I've bought were. I seem to remember pulling the cable from housing on OEM ones and they were greased. I recently bought a NOS one for my Power Wagon. I don't really need it right now, but it was priced right. I'm going to pull the cable and see if there's grease on it. Even after all these years there would still be some.
There are some greases that aren't too effected by temps. I've found "Fifth Wheel Grease" to be very good for applications like this. I use it in my power window gears and tracks on my Diplomat. Very silky regardless of temperatures.
Facts are stubborn things.
[Re: larrymopar360]
#2727456
12/27/19 06:14 PM
12/27/19 06:14 PM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
If the speedo has been tested good and the gizmo at the trans is good, then it can only be the cable.
#1 Make sure there are no hard bends or kinks along the length of the cable. Any bends should be smooth and wide. #2 Any damage to the cable sheathing should be inspected. If it's broken internally and binding against the cable, there's yer problem. #3 I'm not a fan of the dry lubrication. If you live in a moist climate, it has a tendency to get clumpy and not be much of a lubricant. I'd suggest if neither #1 or #2 are your problem, then remove the cable, clean it as best as possible and use an actual lubricant like a light motor oil, Fluid Film, heck, I've even heard of people using cooking oil because it's so light.
Even if you do use a heavier grease for the cable (I have actually used wheel bearing grease, personally) the speedo may be sluggish at lower speeds, but it certainly will not bounce anymore. Chances are you won't be using the vehicle in the winter anyway, so you'll probably never see any ill effects.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: larrymopar360]
#2727457
12/27/19 06:15 PM
12/27/19 06:15 PM
Posts: 21,835 Kirkland, Washington
Pacnorthcuda
There are some greases that aren't too effected by temps. I've found "Fifth Wheel Grease" to be very good for applications like this. I use it in my power window gears and tracks on my Diplomat. Very silky regardless of temperatures. Every cable I remember working on was greased, and the 3 or 4 new ones I bought were also. Sometimes they come with a grease packet. As stated earlier, sharp bends are the enemy. The hardest is usually under the dash, right behind the speedo....you want as straight as possible there.
