Vinyl stripes install questions
#272697
03/31/09 06:29 PM
03/31/09 06:29 PM
Posts: 59 Central Illinois
mity225
Central Illinois
Anybody have any tips for installing vinyl exterior trim stripes? I have 71 Super Bee stripes for my Charger and was just wondering if anyone has any helpful hints on getting them on straight. Anyone use pens of any kind to mark where they go? Should I use a piece of tape for a to show where I want the stripes to butt up against? Any thoughts appreciated! Thanks, JK mity225@mchsi.com
Always looking for my next project!
Re: Vinyl stripes install questions
[Re: mity225]
#272700
03/31/09 08:53 PM
03/31/09 08:53 PM
Posts: 942 Virginia, US
RTDaddy
super street
super street
Virginia, US
I have installed the stripe kit you have on Superbees and R/T's. First, take a good dose of patience, and plan for most of the day, and do them inside. With the curves being compound, and going over compound curves, you are going to be moving the stripes around A LOT. I use windex to spray down the area where the stripes go, and the back of the stripe, (after peeling the backing sheet off of the adhesive side of the stripe). Using a couple of pieces of tape on the hood, one at the back edge about 2" long along the edge, and another parallel to it about 12" towards the front from the back edge, stick these down first before you windex the car. (These two pieces will be running from side to side, not along the length of the hood). Use a tapeline and mark the hood centerline on the tape. Also mark the centerline of the hood stripe on the backing sheet. Spray down the hood, the hood stripe, and lay it on the hood. Stretch a piece of tape from centerline to centerline of the two pieces for reference tape,(over the stripe), then slide the hood stripe back and forth until the centerline for the stripe matches the reference centerline. Use a couple of pieces of tape on the stripe backing sheet and long enough to loop over the back edge fo the hood to hold the hood stripe in place. Then spray down and put on the top of the fender stripes, slide to align with the hood strip, and tape them in place. Repeat the process for the doors and quaterpanel stripes, windexing them but NOT squeegeeing them. Now the fun begins. You will have to slide the top of fender segments back and forth to get the best match on to the hood and door stripes, then adjust the door and quarter stripes. Once you have them, wipe a spot dry under the stripe, and place a strip of masking tape at the bottom edge to help keep the stripe located as you squeegee them down. You need to be careful not to put too much pressure on the squeegee, as you can wrinkle the stripe. Do not try to smooth the stripe at the tops of the fenders and the front of the doors all down at once, and a heat gun will help. Hope this helps, good luck.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
[Re: RTDaddy]
#272701
03/31/09 11:57 PM
03/31/09 11:57 PM
mity225
Central Illinois
Oh, excellent suggestions there. This will be the big weekend project, so I'll have reread these a few times to let it soak in.
Any other thoughts?
Thanks! JK
[Re: mity225]
#272703
04/01/09 09:33 AM
04/01/09 09:33 AM
Posts: 199 douglasville,ga
ramrod
douglasville,ga
Here's what I learned when I put the stripes on my '71 bee clone:
Start with the hood stripe first. It goes 3/4" forward of the rear edge of the hood. Work toward the back of the car from there.
The fender stripes are tricky, because they taper in width. I ended up having to lift and reposition the thin outer stripes on the fender where they meet the hood. I squeezed them in to meet the hood stripe. It's not noticeable because the overall width tapers smoothly.
Trim the facing paper on the ends of each stripe all the way to the edge of the stripe. This will aid in alignment, as the facing can sometimes be difficult to see through.
Study LOTS of pics to get an idea of proper placement, particularly on the doors (under the mirrors) so the stripes end evenly on each quarter panel.
ANY significant trash under the vinyl will show through.
I used Ivory dish soap and water with a Bondo squeegee. It worked well.
"That Plymouth had a Hemi with a Torqueflite."
-Driver
[Re: farmington]
#272704
04/02/09 01:35 PM
04/02/09 01:35 PM
Posts: 1,396 Mass
dgc333
Mass
Go to an auto paint supply place and get a spray bottle of stripe installation liquid.
I tried that stuff once and found for an inexperienced person it doesn't allow you to move the stripe around as much. Dish soap in water is much slipperier but does take longer to dry.
[Re: dgc333]
#272705
04/02/09 03:15 PM
04/02/09 03:15 PM
Posts: 4,046 Minnesota
72blubird
Minnesota
dgc333 method is exactly how I have done them. Works great. when doin final squeeging work from middle out. You can do this yourself just be calm and work at steady pace. Don't panic about any little bumps they will go away when subjected to warm sun, make take a few times.
What was I thinking....
