Wilwood Electric Parking Brake
#2726560
12/24/19 11:27 AM
12/24/19 11:27 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Saw this at the recent PRI show. Thought a few here might find it a useful solution. I have a car i might try it on. Nobody should for a minute consider it an "emergency brake".. My application is an IRS, I'm pondering fabbing a Ti mini solid disc on the rear DS yoke and mounting the brake there.
We'll see.
And I have no connection with Wilwood other then what i have shared here.
Re: Wilwood Electric Parking Brake
[Re: moparx]
#2726608
12/24/19 01:18 PM
12/24/19 01:18 PM
jcc
Bitopia
Actually don't know the price range, didn't ask, but should have. I did in jest ask the Wilwood rep at the show what pad compounds were available for it, he didn't have much of a sense of humor. May not even be released yet.
[Re: jcc]
#2726615
12/24/19 01:24 PM
12/24/19 01:24 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Dynapro Low-Profile Rear Electronic Parking Brake Kit Prod #: 140-15842 Price: $1,819.94
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#2726621
12/24/19 01:37 PM
12/24/19 01:37 PM
jcc
Bitopia
Well, IMO, the bang for buck is just not there at that price point. Nevermind.
[Re: jcc]
#2726697
12/24/19 09:18 PM
12/24/19 09:18 PM
Posts: 1,407 Central Pa
moparjim79
Central Pa
Saw this at the recent PRI show. Nobody should for a minute consider it an "emergency brake".. Educate me please. Why? Is there a reason the majority of new vehicles built in the last 5 years have them? I'm curious now, I'd really like to hear your OPINION
[Re: moparjim79]
#2726703
12/24/19 09:34 PM
12/24/19 09:34 PM
Posts: 8,489 Candler,NC / Myrtle Beach, SC
JDMopar
The ones on new cars are only actuated when the vehicle is placed in park, so it's actually a parking brake. The Wilwood brake would be able to be applied by a switch, and it's all or none. If you tried to use it as an emergency brake, it would lock the rear tires up immediately when you applied the switch. We had them on service bucket trucks at work, and when applied...the truck was locked down and you couldn't budge it! They were made by a company called Mico Brake, and there used to be both hydraulic and electric versions. The latest ones we had were electric. I'm pretty sure jcc meant that it should not be used for a brake in an emergency....like if your regular brakes went out, but only used as a parking brake. 2 totally different things.
[Re: Stanton]
#2726721
12/24/19 11:42 PM
12/24/19 11:42 PM
jcc
Bitopia
The "why", all the above and the fact the parking brake disc pad is about the size of my thumbnail.
[Re: jcc]
#2726777
12/25/19 11:32 AM
12/25/19 11:32 AM
Posts: 19,921 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Had one on my CJ-7 trail rig. Worked great to hold me in place on hills if I got stuck, stalled, etc...especially with the manual trans.
Earning every penny of that moderator paycheck.
DBAP
[Re: jcc]
#2726860
12/25/19 05:21 PM
12/25/19 05:21 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I have a master cylinder with a handle dedicated to a seperate caliper for an e-brake and you could adapt a locking pin to be a parking unit. Saw this at the recent PRI show. Thought a few here might find it a useful solution. I have a car i might try it on. Nobody should for a minute consider it an "emergency brake".. My application is an IRS, I'm pondering fabbing a Ti mini solid disc on the rear DS yoke and mounting the brake there.
We'll see.
[Re: JDMopar]
#2730323
01/05/20 03:35 PM
01/05/20 03:35 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
The ones on new cars are only actuated when the vehicle is placed in park, so it's actually a parking brake. The Wilwood brake would be able to be applied by a switch, and it's all or none. If you tried to use it as an emergency brake, it would lock the rear tires up immediately when you applied the switch. We had them on service bucket trucks at work, and when applied...the truck was locked down and you couldn't budge it! They were made by a company called Mico Brake, and there used to be both hydraulic and electric versions. The latest ones we had were electric. I'm pretty sure jcc meant that it should not be used for a brake in an emergency....like if your regular brakes went out, but only used as a parking brake. 2 totally different things. There are actually some production vehicles that now use the electronic parking brake caliper as a failsafe support when there is a failure of something like a brake line or a booster. Since it's basically just a motor that runs it they don't necessarily have to have it be a digital on or off. I think at some point we will have some aftermarket kits for this based on OEM calipers since they are so common now days. Now the actual need for this is a real question for me.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Sniper]
#2730333
01/05/20 04:13 PM
01/05/20 04:13 PM
Posts: 32,935 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Emergency brake is a term used by those that do not understand the function of the parking brake.
Remember all the Mopars with the T handle under the dash to apply the parking brake? Not much braking force using your off hand there. Which is why you set the parking brake by first applying the service brakes fully, on Mopars with the parking bake in the rear drums, not at the trans. Not a very effective "emergency brake" when it locks the handle/pedal in place with each application. As mentioned, it'll likely worsen the situation in most cases when you panic, jam the brake on and lock up the rears.
A random look at an FSM, 70 Dodge in this case, calls it a parking brake and goes into how it function as one. With both the handle and foot operated parking brake you can control the amount of braking by keeping the handle turned or the release handle pulled so they don't lock. I have driven using the old emergency brakes with very little issue. Just didn't go fast or a long way. I'd be willing to bet I'm not the only one.
[Re: stumpy]
#2730405
01/05/20 09:44 PM
01/05/20 09:44 PM
jcc
Bitopia
One other item I neglected to inquire about this solution when I first saw it, "does Willwood suggest they be used singly or as a pair?", and then the next question, what rear differential is complementary if used singly .
[Re: jcc]
#2730407
01/05/20 09:53 PM
01/05/20 09:53 PM
goldduster318
Lake Orion, MI
One other item I neglected to inquire about this solution when I first saw it, "does Willwood suggest they be used singly or as a pair?", and then the next question, what rear differential is complementary if used singly . It has to be a pair. You will not get enough holding torque out of one.
