How good is Indy's cnc port work #2726447
12/23/19 07:51 PM
12/23/19 07:51 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Asking for a friend. How good is the work on their cnc porting? Considering getting bare cnc heads from them (thru a dealer of course) to be vj'ed and filled with good hardware from said dealer. You guys making any good power with their ports?
Re: How good is Indy's cnc port work [Re: Hot 340] #2726463
12/23/19 08:45 PM
12/23/19 08:45 PM
AndyF Offline
AndyF  Offline
Call Porter Racing Heads
Re: How good is Indy's cnc port work [Re: AndyF] #2726469
12/23/19 09:38 PM
12/23/19 09:38 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
So how fast have you've gone with them?
Re: How good is Indy's cnc port work [Re: Hot 340] #2726472
12/23/19 09:53 PM
12/23/19 09:53 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Which heads, Dwayne has done different sets for a couple of my motors. He will get you lined out. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: How good is Indy's cnc port work [Re: BANDIT] #2726474
12/23/19 10:07 PM
12/23/19 10:07 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Larry Smith in North Carolina does great work. Fast turnaround too. Very reasonable if you want hand port work.
I personally would find someone who does CNC porting.
Re: How good is Indy's cnc port work [Re: Hot 340] #2726479
12/23/19 10:15 PM
12/23/19 10:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
Buy your new Indy heads from either Modern Cylinder heads with their CNC porting(586-468-7914) or Bob George racing (724-941-4251,ask for A.J.) to get a good job on the heads at a reasonable price from both of them scope
Re: How good is Indy's cnc port work [Re: Cab_Burge] #2726482
12/23/19 10:18 PM
12/23/19 10:18 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Not sure I’d go “Modern”.... seem to keep reading issues concerning things like “timely manner” and “communication”.
Re: How good is Indy's cnc port work [Re: Hot 340] #2726484
12/23/19 10:21 PM
12/23/19 10:21 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Dwayne is an Indy dealer as well.
Re: How good is Indy's cnc port work [Re: mopar dave] #2726487
12/23/19 10:40 PM
12/23/19 10:40 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Been on here since 06. I know who the dealers are guys. Anybody making power with Indys portwork? Or are they turbulent junk?
Re: How good is Indy's cnc port work [Re: Hot 340] #2726498
12/23/19 11:20 PM
12/23/19 11:20 PM
AndyF Offline
AndyF  Offline
I don't recall ever running a set of Indy ported heads. That is why I told you to call Porter Racing Heads. He uses a lot of Indy CNC ported heads so he'll know which heads are good and which aren't so good. There are a ton of choices so you need to figure out which head you're interested in first.
Re: How good is Indy's cnc port work [Re: AndyF] #2726527
12/24/19 09:11 AM
12/24/19 09:11 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Indy programs aren't terrible, and some are actually pretty good. The trouble has historically been the terrible VJ, the horrible blending, often with either .003-.005 guide clearance, or, even worse, .0005 on the exhaust lol. Or a big ole curl of aluminum under the seats so the fall out in the oven.
The human part is where a good program goes to die. Also core shift castings, with porosity that leak.
I've had them port heads before with no seats, and no guides.
Re: How good is Indy's cnc port work [Re: Hot 340] #2726546
12/24/19 11:01 AM
12/24/19 11:01 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
IIRC Dwayne used one 345 cnc-1 head with his own valvejob into the 900HP range. Dartin' has the same Indy head/program on his 540" and is making 850ish with a milder combination but again valve-jobed before use.
Re: How good is Indy's cnc port work [Re: HardcoreB] #2726548
12/24/19 11:04 AM
12/24/19 11:04 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Like has been mentioned, it's better if you can buy the cnc core ported OR have it done independently.
Re: How good is Indy's cnc port work [Re: Hot 340] #2726575
12/24/19 11:56 AM
12/24/19 11:56 AM
New York
polyspheric Offline
polyspheric  Offline
New York
A good porter will give you a heads up on your cam choice as well.
Boffin Emeritus
Re: How good is Indy's cnc port work [Re: polyspheric] #2726583
12/24/19 12:17 PM
12/24/19 12:17 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The "Best of Moparts / Tech Archive" forum has some older posts by Dwayne Porter "fast68plymouth" that include before & after prep results for a variety of Indy BB heads, including some of the ICH CNC-ported options. No, I don't have links to them.
Re: How good is Indy's cnc port work [Re: HardcoreB] #2726590
12/24/19 12:33 PM
12/24/19 12:33 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I know someone who has the 345's on a 440ci sbm (4.185x4). Its gone mid 9's in Avenger not a very light one either. It would be best to know what the current combo is, or the expectations.
Re: How good is Indy's cnc port work [Re: B1MAXX] #2726602
12/24/19 01:14 PM
12/24/19 01:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
I think the Indy programs are pretty good....... but if you’re trying to build something that requires something “more” that what they can deliver....... then going a different route may be a better option.
Re: How good is Indy's cnc port work [Re: J_BODY] #2726625
12/24/19 02:09 PM
12/24/19 02:09 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
X2. I've been waiting 3-1/2 years for Bob to make me a set of SS Hemi heads. I sure as heck wouldn't give him any money up front and use a credit card to pay when he's ready to ship. I've called numerous times, get the voice mail machine. I never get any calls back, no return e-mails. He has time to post on FaceBook. I wouldn't recommend Bob to anyone. I had good luck with Jeff, a set of iron bracket Hemi heads and a set of W2s that Jeff did for me. Bob is not Jeff.
Floyd Lippencott IV
Re: How good is Indy's cnc port work [Re: mr_340] #2726626
12/24/19 02:23 PM
12/24/19 02:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I cannot speak for all their selectons. I have had a few sets of their CNC stuff and currently have one set on the dragster. I can tell you there Predator stuff is ok. My heads actually went to Slawko after coming from Indy with their CNC work. Tom did some massaging to them and they were certainly better, that with his valve job we picked up 20 average Hp. May not sound like a lot of this is a 1200HP deal. A second set were done right after mine were used for his new cnc program and that set is on a single 4 70GTX all steel all glass street strip car and runs 8's NA...
Re: How good is Indy's cnc port work [Re: mr_340] #2726663
12/24/19 04:37 PM
12/24/19 04:37 PM
Superfreak
Superfreak
I couldn't even get a quote for new heads from Bob
