Brake Line Vendors #2726268
12/22/19 09:54 PM
12/22/19 09:54 PM
Usa
A39Coronet Offline OP
Usa
Who do you like using for brake line replacement? I ordered a set from Right Stuff and every single line needed adjusted and modified. The front lines that went under the frame from the distribution block to the flex lines weren't bent wide enough to clear the frame by over an inch (the "U" shaped valley is narrower than the frame is wide by over an inch). Is this par for the course or are they're more accurate companies out there?
It even appears they put the wrong firewall line in the box as it was tagged with a different part #.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Brake Line Vendors [Re: A39Coronet] #2726275
12/22/19 10:35 PM
12/22/19 10:35 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Used In line tube... brake lines fit fine....but I think you will alway have to slightly bend etc......
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Brake Line Vendors [Re: JMCFAN] #2726553
12/24/19 11:21 AM
12/24/19 11:21 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I got my stuff from classic tube, they are local to me and can pick up.
Jeff
Re: Brake Line Vendors [Re: Cuda340] #2726770
12/25/19 11:04 AM
12/25/19 11:04 AM
None
71rm23 Offline
71rm23  Offline
None
In-line here up
Re: Brake Line Vendors [Re: A39Coronet] #2726887
12/25/19 07:37 PM
12/25/19 07:37 PM
iowa
copchaser Offline
copchaser  Offline
iowa
I use Inline Tube. I've tried all of the venders, they all have issues. I've found Inline to be about the best fitting.
Re: Brake Line Vendors [Re: copchaser] #2726896
12/25/19 08:05 PM
12/25/19 08:05 PM
BlueRacer69 Offline
BlueRacer69  Offline
Same here, Inline tube. up
Re: Brake Line Vendors [Re: A39Coronet] #2727309
12/27/19 10:23 AM
12/27/19 10:23 AM
Usa
Usa
Thanks all. I ended up sending this kit back and Jegs suggested I contact Right Stuff directly. The rep said that they've had this design since 1989, and wanted me to send over a side by side pic of my oe lines. Going to look into the companies suggested above instead.
Re: Brake Line Vendors [Re: A39Coronet] #2727320
12/27/19 10:57 AM
12/27/19 10:57 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Right Stuff is fairly local to me and I liked using them because I did not have to deal with having to straighten the lines. In the early days got great personal customer service.
But they are not as good in my opinion as they used to be since they got bought out by a large company a few years ago. They lost the personal service touch now that they are much bigger. Last time I bought lines from them they were fair.
