Torque plate studs or bolts... #2725936
12/21/19 07:01 PM
12/21/19 07:01 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
I'm ready to bring my big block motor to the machine shop, I prefer to use studs on this engine.
The shop have torque plate for my motor.
May be a novice question, but must I use my studs for machining or bolts from the shop will be fine...
Thanks.
Re: Torque plate studs or bolts... [Re: STROKIE] #2725942
12/21/19 07:24 PM
12/21/19 07:24 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I don't think you can use your studs, unless you have 34 short studs or a bunch of spacers. I have my own plates and a set of studs. What does the machine shop have for setup?
Joe
Without Data, you’re just another guy with an opinion.
Re: Torque plate studs or bolts... [Re: sr4440] #2725953
12/21/19 07:41 PM
12/21/19 07:41 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
Joe
I don't know I will ask, but I'm pretty sure they don't have a set of short studs...
Probably they have bolts, but may be I'm a little bit too much of a perfectionist weakness. frown
Re: Torque plate studs or bolts... [Re: STROKIE] #2725970
12/21/19 08:33 PM
12/21/19 08:33 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ask Nick ... he's in your home town !!!
Re: Torque plate studs or bolts... [Re: Stanton] #2725975
12/21/19 08:50 PM
12/21/19 08:50 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
Thanks for your suggestion....
He's the guy. thumbs
Re: Torque plate studs or bolts... [Re: STROKIE] #2725986
12/21/19 09:29 PM
12/21/19 09:29 PM
To preload the top of all the cylinder walls correctly you need to use the same type fasteners as will hold the heads on as well as have the same thread engagement in the block bolt holes up scope
I have spacers for the five center head bolts to simulate the same loading as the motor will have with head bolts or studs for my steel BHJ honing plate.
Re: Torque plate studs or bolts... [Re: Cab_Burge] #2725996
12/21/19 11:09 PM
12/21/19 11:09 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
This!
Re: Torque plate studs or bolts... [Re: Cab_Burge] #2726010
12/22/19 07:47 AM
12/22/19 07:47 AM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
Thank you...
Re: Torque plate studs or bolts... [Re: STROKIE] #2726247
12/22/19 08:37 PM
12/22/19 08:37 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Head gasket or no head gasket?
Re: Torque plate studs or bolts... [Re: Uberpube] #2726281
12/22/19 11:41 PM
12/22/19 11:41 PM
I've always provided a head gaskets exactly like the ones that would be used on the motor up
Re: Torque plate studs or bolts... [Re: Cab_Burge] #2726316
12/23/19 08:00 AM
12/23/19 08:00 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Spacers/ studs
Re: Torque plate studs or bolts... [Re: TRENDZ] #2726363
12/23/19 11:54 AM
12/23/19 11:54 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
let me guess you guys also number your bolt/studs so that they go in the same hole. I usually put short studs/bolts the whole way around. I have dedicated sets that I keep with the plates.
Re: Torque plate studs or bolts... [Re: B1MAXX] #2726381
12/23/19 01:18 PM
12/23/19 01:18 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
What are these torque plates you guys speak of. LOL.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Torque plate studs or bolts... [Re: pittsburghracer] #2726400
12/23/19 02:47 PM
12/23/19 02:47 PM
PA
O
Ody1003 Offline
Ody1003  Offline
O
PA
There just like the ones that were used on your 422 small block before you got your hands on it. Ha ha
Re: Torque plate studs or bolts... [Re: Ody1003] #2726407
12/23/19 03:19 PM
12/23/19 03:19 PM
PA.
"Little"John
"Little"John
PA.
It will probably never see one again. Lol.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Torque plate studs or bolts... [Re: pittsburghracer] #2726485
12/23/19 10:24 PM
12/23/19 10:24 PM
Wait until you hone a Mopar SB 10 head bolt block that wasn't hone with a plate when you use a plate to hone it for new rings shock work shruggy
I did that once, none of the SB I build now get done without honing the block with a torque plate twocents
Re: Torque plate studs or bolts... [Re: Cab_Burge] #2726490
12/23/19 10:49 PM
12/23/19 10:49 PM
PA.
"Little"John
"Little"John
PA.
My stock block 360’s run pretty good without it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Torque plate studs or bolts... [Re: pittsburghracer] #2726597
12/24/19 12:42 PM
12/24/19 12:42 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The only one I saw shadows when honing was a big block Chevy, with and without a plate.
Re: Torque plate studs or bolts... [Re: pittsburghracer] #2726632
12/24/19 02:46 PM
12/24/19 02:46 PM
When you want it to run its best use the honing plate up twocents
