Re: Changing bolt pattern on 88 D100 ?
[Re: JDMopar]
#2725867
12/21/19 01:58 PM
12/21/19 01:58 PM
Posts: 16,832 Between Houston & Galveston TX
SattyNoCar
While I haven't personally done it, I'm pretty sure it's just a matter of swapping rotors. '84 was the last year for the 5 on 4.5 bolt pattern. I briefly owned an '84 and any of the older rims fit just fine (I installed a set of those aluminum Cordoba rims on mine). Rock Auto Linky
John
[Re: JDMopar]
#2725875
12/21/19 02:48 PM
12/21/19 02:48 PM
SattyNoCar
Yes, it's a link to an '84 rotor on rock auto. They're about $35 ea. There are several brands available from them.
Cop rims will fit. I ran those before switching to the 'Doba wheels.
$55 drum to drum? Cool score! What's it out of? C-bodies and B-body WAGONS share the same width axle as a truck, just need new pads welded on. A '76 PU I had I swapped in a 9 1/4 from a ' 77 C-body.
John
[Re: scratchnfotraction]
#2726442
12/23/19 07:21 PM
12/23/19 07:21 PM
Posts: 8,499 Candler,NC / Myrtle Beach, SC
JDMopar
Thanks Scratch! The rearend I bought came out of a 68 D100, so it's the 4.5 bolt pattern. My cousin used to have a 74 Powerwagon with the 5.5 bolt pattern, but it's long since been deceased! Only thing left of it is the original 318 sittin in my basement....lol. So, when I get around to doing this, all I need is new 82-84 rotors, correct? They will work on my existing 88 spindles, right? The rear brakes I got figured out.
