P7 Heads on a ritter block
#2725487
12/19/19 10:12 PM
12/19/19 10:12 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
I'm not a "Mopar Guy" so I'm asking this out of pure curiosity , but can you bolt a set of the P7 heads on to the New Ritter Block ? I Bought a 65 Dart last week , been debating on going BBM or Sbm,
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
Re: P7 Heads on a ritter block
[Re: Ray408G3Hemi]
#2725511
12/20/19 12:03 AM
12/20/19 12:03 AM
Posts: 11,635 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
There is a version of the Ritter that is machined for the P7. They are not interchangeable with any other head. I don't believe it is (was?) an easy build but has been done. And the tall deck LA style block can be built bigger than the R5. Being in PA you are fairly close to guys who did it. A complete R5P7 is also an option that would likely be easier and cheaper than the Ritter deal.
Your budget will determine which options are available and sensible.
[Re: Ray408G3Hemi]
#2725540
12/20/19 07:59 AM
12/20/19 07:59 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The P7 head will not fit a standard small block without extensive modifications. As far as I know, the ritter block for p7 heads never was available to the general population. I have a complete P7 top end and cam. I also have an A8 block that I want to mate them to. Bore space is the same. Head bolt holes need to be moved. Cam tunnel needs to be removed and replaced. The P7 lifter bore requires location in the area that currently has cam bearings. The standard block has 5 cam bearings where the p7 requires 7 cam bearings. Call ritter and see if they have the xr block for P7s available. If they do, it would be an awesome combo. Also would likely need to fabricate an intake and water manifold.
[Re: usp4u]
#2725557
12/20/19 09:15 AM
12/20/19 09:15 AM
TRENDZ
Milwaukee WI
Its a shame that that info isn’t out there. I was asking about that block for years before assuming it would never happen.
[Re: usp4u]
#2725559
12/20/19 09:20 AM
12/20/19 09:20 AM
Ray408G3Hemi
Springtown Pa
Last time I was at Ritter's place he was trying hard to sell me his "new" (v2.0) block for P7 heads. Dude must 100 pair of assembled P7s on the shelf from Arrington/Penske/Chapman/etc.
Call Kent, he has want you need on the shelf/shelves. Can I get a hold of them thru Hughes , or should I go Direct ?
[Re: CMcAllister]
#2725567
12/20/19 09:45 AM
12/20/19 09:45 AM
Posts: 2,049 MD
RTSE4ME
MD
Your budget will determine which options are available and sensible. The guys with the green Dart?
[Re: Ray408G3Hemi]
#2725569
12/20/19 09:52 AM
12/20/19 09:52 AM
Posts: 165 W. Pa
usp4u
W. Pa
Call Kent, he has want you need on the shelf/shelves. Can I get a hold of them thru Hughes , or should I go Direct ? I would just call him.
[Re: Ray408G3Hemi]
#2725639
12/20/19 01:45 PM
12/20/19 01:45 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Ray if you are thinking about doing a hotdog smallblock I would start with a phone call to Brett Miller.
"Just a Bracket car dressed up like a streetcar"
[Re: Dragula]
#2726198
12/22/19 06:26 PM
12/22/19 06:26 PM
Posts: 6,147 Melbourne , Australia
LA360
The Ritter XR2 block takes all the LA stuff, the nose of the camshaft needs to be machined to like a LA camshaft as well. If you're a perfectionist, you could go down the road of a custom cam core. The ritter blocks were designed around the P7 heads, the wedge stuff was made to work around it.
Alan Jones
[Re: LA360]
#2726205
12/22/19 06:45 PM
12/22/19 06:45 PM
TRENDZ
Milwaukee WI
Is the XR2 iron or aluminum? Are the available now? What is the price range? Been waiting on this for 10+ years.
[Re: TRENDZ]
#2726225
12/22/19 07:41 PM
12/22/19 07:41 PM
LA360
These blocks have been available for as long at the Ritter blocks have, so they will be priced similarly to the XR1 wedge blocks. I have a couple of iron blocks, I believe that aluminium was available as well. Kenny Badorf has an aluminium XR2/P7 deal with a Procharger in his Dart from memory
Alan Jones
