Freeze plugs... kinda long (UPDATE)
#272527
03/31/09 03:35 PM
03/31/09 03:35 PM
Posts: 803 Fl. USA
PS Arrow
Fl. USA
Well...finally got a good chance to cruise the Arrow today and see where the temp is going to level off at. Its about 80-82 I guess today and stop and go traffic in town it would get to about 205 and then drop to 190-195 when cruising. I cooled it off and then decided to meet my wife for lunch, took the car into town it got to about 185 and parked, I didnt want to leave the fan and water pump running so shut it all down. When I came back out after about 30-40 minutes the temp was still about 160 and it had a puddle under the car. It was a little slow to start, turned over fine, but just didnt want to fire, almost acted like it was flooded, I held the throttle wide open, cranked it and finally it fired off and ran fine. Drove home to get the hood off and find water peeing out from a freeze plug. It will be easy enough to change it after I get the front tire and the header off.
Here's my question... Why? Other than just a bad freeze plug installation. I never like to just turn one off hot with out the water pump and fan to keep going until it cools, but, we do it all the time in our daily drivers my truck runs all day at 195 and I'll shut it off and walk away after driving 4 hrs. I have a closed system on the cooling system for recovery with an 18 PSI recovery radiator cap. I may just be paranoid but, I just ordered a Moroso thermostatic switch, I'm going to wire the water pump and the fan to, it comes on @ 160 and off @ 140, this I hope will help, just more wiring I need to add to the car.
Any thoughts?
Re: Freeze plugs... kinda long
[Re: MR_P_BODY]
#272529
03/31/09 04:49 PM
03/31/09 04:49 PM
Posts: 803 Fl. USA
PS Arrow
Fl. USA
What stat is in it... did you make a shroud
I dont have a t-stat in it, though I am starting to rethink that, my logic was if it's running this warm w/out one wont it just stay open all the time and still run where it's at?
No I havent gotten to the shroud, it's so tight up front not quite sure the best way to build one. I have a single 2500 cfm fan as a puller, not much room for a second one. Once its shut off it cools really quick with the fan and pump running. I can live with the running temp, not sure what it will do in the heat of the summer, I'm sure it will increase, I really just dont like the dead head heat once it's shut down. But do you think a T-stat would regulate the temp?
Post deleted by Defbob
[Re: PS Arrow]
#272531
03/31/09 06:03 PM
03/31/09 06:03 PM
Re: Freeze plugs... kinda long (UPDATE)
[Re: PS Arrow]
#272535
04/08/09 09:53 AM
04/08/09 09:53 AM
Posts: 803 Fl. USA
PS Arrow
Fl. USA
Well, I sorta have my freeze plug issue figures out for the moment atleast. Thanks to Mr.P body, Advance has the plugs on order, cant get them until Monday; but I have a temporary fix in place.
I put a switch in the cooling system so I can park the car and turn it all off and walk away, but keep the fan and water pump running, it opens @ 160 and closes @ 140 degrees. Drove the car this morning, with out the front end on it so it took longer to warm up, finally got it to read 160, then came back to the house and let it idle until the gauge read 180. I put a thermometer in the radiator and it was only right @ 162 degrees. I shut the car off and the fan and water pump continued to run as planned. I kept the thermometer in the radiator until everything shut down, it was right at 140 degrees, but the gauge in the car was still at 160. I understand I am not using calibrated equipment, and also the fact that the water has passed through the cooling fins with the fan running, but the switch operated right at the advertised temps and the gauge in the car was still 20 degrees higher. Should I replace the gauge? Or just keep in mind it reads a bit higher than actual temp?
I'm still working on engineering a fan shroud.
I still have not put a thermostat in it, I broke the t-stat housing I had (not a Mopar piece) and bought the Summit swivel housing, works OK but its engineered for another brand and will not fit my t-stat. I need to find a swivel housing that will work on the aluminum housing and use the Mopar t-stat, or find out if a GM t-stat will work in my housing. Any thoughts? Thanks, John
[Re: PS Arrow]
#272536
04/08/09 10:16 AM
04/08/09 10:16 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I mark on my gauges where it should be (for the operating pressure or temp). If you open the back of the gauge yours might be adjustable to set the zero... set it to your thermometer reading. The stat, a GM should be fine, drill some holes in it
[Re: MR_P_BODY]
#272537
04/08/09 06:08 PM
04/08/09 06:08 PM
John, I use water wetter or that royal purple water treatment..It makes about a 10-15* difference.
[Re: PS Arrow]
#272538
04/08/09 11:19 PM
04/08/09 11:19 PM
Posts: 43,283 Bend,OR USA
Cab_Burge
I have seen many manual(non electric) aftermarket temperature gauges read high like yours, Autometer, Stewart Warner, Autogauge and so on. A freind of mine is having the same problem as you are right now with his gauge reading around 35F high at low temps, 100F actual reads 140F and it gets closer when it gets warmer, 160F actual reads 180F on the gauge in the car(verifying with a infra red hand held and several good quality industrial thermometers So much for good quality American made gauges
