70 Road Lamp Relay #2724907
12/17/19 07:39 PM
12/17/19 07:39 PM
NJ
moparply Offline OP
moparply  Offline OP
NJ
Does anyone know how to test a 70 Road Lamp Relay when out of a car? Thanks
Re: 70 Road Lamp Relay [Re: moparply] #2725116
12/18/19 12:56 PM
12/18/19 12:56 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
Sure. Looking at the circuit board and the mounting flange on the right side, you can measure the impedance between the upper left terminal and the relay metal body. That reading should be between 45 to 50 Ohms of resistance. If there is no impedance reading, it would appear to be a non working relay. That is the input trigger when 12 volts applied between these two positions, will close the relay and you will hear a click. The center terminal and the upper right terminal is the output side. It can be tested "dry" without 12 volts applied to this output side. Measure the resistance between the center and upper right terminal. That reading should be 0 Ohms of resistance. Any resistance will decrease the brightness of the road lamps.
These can be restored. wink
Re: 70 Road Lamp Relay [Re: Slotts] #2725118
12/18/19 01:00 PM
12/18/19 01:00 PM
Kirkland, Washington
Pacnorthcuda Offline
Most of us don’t own impedance testers. Most all of us DO own ohmeters.
Re: 70 Road Lamp Relay [Re: Pacnorthcuda] #2725158
12/18/19 04:11 PM
12/18/19 04:11 PM
NJ
moparply Offline OP
moparply  Offline OP
NJ
Thanks guys. I will give this a try.
