Cons of running studs in full winter snow tires? #2724747
12/17/19 11:14 AM
12/17/19 11:14 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Going to order 4 full winter studable (sp?) snow tires (General Altimax Arctic 12 ) for a rear wheel drive family car and Tire Rack will stud all four for an additional $15. I've never run studs and heard bad things about noise on dry roads and the studs flying out and damaging the car but that was long ago. Are current studs and current studded snow tires better? Should I try them especially for only $15 for all four. Read studs are legal in Ohio from November 1st to April 15th and I most likely will only have them on from December to March on dedicated wheels during that time. What's the cons of running studded snow tires" Thanks in advance.
Mike
Re: Cons of running studs in full winter snow tires? [Re: A12] #2724752
12/17/19 11:25 AM
12/17/19 11:25 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
There are laws regarding when you can and cannot run studded tires, if you haven't looked at those you might want to and see if it will cause you any issues.
Re: Cons of running studs in full winter snow tires? [Re: Sniper] #2724755
12/17/19 11:33 AM
12/17/19 11:33 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Quote
5589.081 Studded tires - prohibited acts.
(A) For purposes of this section, "studded tire" means any tire designed for use on a vehicle and equipped with metal studs or studs of wear-resisting material that project beyond the tread of the traction surface of the tire; and "motor vehicle," "street or highway," "public safety vehicle," and "school bus" have the same meanings as given those terms in section 4511.01 of the Revised Code.
(B)
(1) Except as provided in division (B)(2) of this section, no person shall operate any motor vehicle, other than a public safety vehicle or school bus, that is equipped with studded tires on any street or highway in this state, except during the period extending from the first day of November of each year through the fifteenth day of April of the succeeding year.
(2) A person may operate a motor vehicle that is equipped with retractable studded tires with the studs retracted at any time of the year, but shall operate the motor vehicle with the studs extended only as provided in division (B)(1) of this section.
(C) This section does not apply to the use of tire chains when there is snow or ice on the streets or highways where such chains are being used, or the immediate vicinity thereof.
Re: Cons of running studs in full winter snow tires? [Re: Sniper] #2724756
12/17/19 11:34 AM
12/17/19 11:34 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
You get better traction on ice and hard-packed snow, and worse traction on everything else--wet roads, dry roads, and soft snow.
And you already mentioned the noise and the possibility of throwing them.
They are great at certain times in certain conditions.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Cons of running studs in full winter snow tires? [Re: A12] #2724757
12/17/19 11:37 AM
12/17/19 11:37 AM
moparx Online content
moparx  Online Content
if you normally get a lot of snow and ice during the winter, the studs are worth it.
about the only time the studs fly out, is if they are not fully seated in the tire when installed, the tire is wore out, or you spin excessively trying to get unstuck or jackrabbit starts.
as to the noise on dry pavement, that's the nature of them. also, they may have a tendency to slide quicker in a panic stop.
just my experience running studded tires on and off for over 50 years.
i have studded tires on just the front of my minivan, and it goes places some with 4wd would be afraid to try.
beer
Re: Cons of running studs in full winter snow tires? [Re: moparx] #2724789
12/17/19 12:41 PM
12/17/19 12:41 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I concur as I also run studs on my minivan.
Studs make a night and day difference in traction on snow and ice. They run quieter and wear a lot longer than you would think.
Re: Cons of running studs in full winter snow tires? [Re: A12] #2724793
12/17/19 12:56 PM
12/17/19 12:56 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Mike, we live near each other, and I've run both studded and non-studded snows. With the amount of snow we get, I didn't think that studs were beneficial. If lived up north (MN, WI, Dakotas, MT, etc...), I am sure the benefits would be much greater. A good quality set of snow tires by themselves should be plenty sufficient for what we typically deal with. The snows on my wife's Subaru (Michelin Ice-X), and my daughter's Civic (Bridgestone Blizzak), have been fantastic. My $.02.
Earning every penny of that moderator paycheck.
DBAP
Re: Cons of running studs in full winter snow tires? [Re: not_a_charger] #2724799
12/17/19 01:16 PM
12/17/19 01:16 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
We get significant snow & ice here in N. Idaho, been here 15 years, with my DD snow rigs being a Breeze and a Pathfinder.
Winter tires on both, studded on Pathfinder.
Studs are a bit better on ice, not much different in snow, but driving them on clear/dry roads kills them.
A bit of noise, but doesn't bother me. Traction's the priority.
Winter tires being softer, aggressive tread, & siped, have been fine on the Breeze.
Winter tires seem to last forever, but they do loose effectiveness even when there appears to be a fair amount of tread.
Between the 2 rigs, I've taken to driving the Breeze in winter, and put a backblade on the Pathfinder.
Re: Cons of running studs in full winter snow tires? [Re: topside] #2724803
12/17/19 01:27 PM
12/17/19 01:27 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran them on my 65 years ago.Never had any problems even back in 60s tossing studs on normal drives.I did have fun when it was dry lighting them up at night.They would make some decent sparks.Rocky
Chrysler Firepower
Re: Cons of running studs in full winter snow tires? [Re: A12] #2724804
12/17/19 01:32 PM
12/17/19 01:32 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Altimax Arctic 12's are very good tires. I live in snow country (Wisconsin). I've never considered studding them. Have two sets on two cars.
Re: Cons of running studs in full winter snow tires? [Re: A12] #2724806
12/17/19 01:38 PM
12/17/19 01:38 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Re: Cons of running studs in full winter snow tires? [Re: moparx] #2724816
12/17/19 02:02 PM
12/17/19 02:02 PM
Buckeye Lake
56_Royal_Lancer Offline
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Originally Posted by moparx
"...i have studded tires on just the front of my minivan, and it goes places some with 4wd would be afraid to try.
beer
Like down the cliff at Mike's Supermarket whistling
Re: Cons of running studs in full winter snow tires? [Re: 56_Royal_Lancer] #2724830
12/17/19 02:18 PM
12/17/19 02:18 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
beer
haha
Re: Cons of running studs in full winter snow tires? [Re: wingman] #2724841
12/17/19 02:35 PM
12/17/19 02:35 PM
Kirkland, Washington
Pacnorthcuda Offline
Studs are great on snow and ice. They suck on bare dry or wet pavement (ie panic stops) so one really should drive conservatively on them.
Re: Cons of running studs in full winter snow tires? [Re: moparx] #2724844
12/17/19 02:38 PM
12/17/19 02:38 PM
beer
There isn’t a minivan in the world that can keep up with my Rubicon when the traction gets rough.
Re: Cons of running studs in full winter snow tires? [Re: Pacnorthcuda] #2724848
12/17/19 02:52 PM
12/17/19 02:52 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
beer
EXCEPT its a Jeep...so there are those annoying trips to the dealer for warranty issues...other than that
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Cons of running studs in full winter snow tires? [Re: A12] #2724855
12/17/19 03:11 PM
12/17/19 03:11 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The wife's 06 Charger Daytona is her daily driver and it gets studded snow tires put on it every winter (they get taken off in the spring.
Re: Cons of running studs in full winter snow tires? [Re: SNK-EYZ] #2724936
12/17/19 09:15 PM
12/17/19 09:15 PM
5thAve Offline
5thAve  Offline
We live in the only part of Canada that you're not allowed to run studded tires and boy i'd love to have them for a change.
I couldn't even get up my street tonight. However I blame traction control for that as I was moving perfectly fine until that kicked on.
Re: Cons of running studs in full winter snow tires? [Re: 5thAve] #2724991
12/17/19 11:51 PM
12/17/19 11:51 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I've lived in WI my whole life(58 yrs) Never once thought about studded tires....not even sure they're legal. A good 4x4 is handy to have but otherwise they clear the roads very well.
Re: Cons of running studs in full winter snow tires? [Re: Dcuda69] #2725030
12/18/19 05:27 AM
12/18/19 05:27 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
A12, look at it this way, you've lived in NEO for how long and never needed them before.
Angry white pureblood male
