How big of a rear tire on you 1971-1974 Dodge Charger. #2723217
12/11/19 12:25 PM
12/11/19 12:25 PM
San Jose,CA
migsBIG Online happy OP
YouTube is my go-to news source
migsBIG  Online Happy OP
San Jose,CA
I had opened a discussing on front wheel size and decided to see what guys were running on the rear of their 3rd gen Chargers. I always believe in the rear tires should be HUGE crowd, but thinking good road manners, traction and road noise should be addressed as well. I am considering stock style wheel for dog dish, diam 15X10 4.5 back spaced wheels with Cooper Cobra 295/50R15. I don't think I will have issues with those even though I will have passenger in my 72' Charger Rallye. It will have MP hipo leaf springs and stock swaybar. What sizes are you guys running?
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: migsBIG] #2723222
12/11/19 12:45 PM
12/11/19 12:45 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: 71charger] #2723237
12/11/19 01:23 PM
12/11/19 01:23 PM
Kirkland, Washington
Pacnorthcuda Offline
295/50/15 are a GREAT tire size.......when they fit.
You are rolling the dice. Often they don’t fit. Manufacturing tolerances, a 50 year old car that has shifted just a bit over the years, never was perfect sized to side to begin with etc. Backspacing often needs to be dead on.
275/60’s are a much safer bet, but not quite as wide of course, which sucks.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: Pacnorthcuda] #2723387
12/12/19 07:27 AM
12/12/19 07:27 AM
San Jose,CA
San Jose,CA
Thanks for the link, it helped me remember that even if it's the biggest tire fits, that it may not 'look right' when mounted. I would like it to fit and look good with it not going too far in out. Going to pull up some pics of my cuda with oversize wheels (currently at another shop) and see how those measure up in comparison to the charger specs..
yeah, Gonna have to measure that back spacing to e sure. not worried on the chassie specks too bad. Nice when it was a little old lady owned 92k mile semi-survivor I started with (rear swaybar bushing still looked like new and was pretty clean in the rear). 15X8 in the front may work well with 4"in back space and a 245/50 tire, but the rear is going to need some research for sure. Might have to save the wheels for last and do more checking into these bodies to see what's gonna work with it.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: migsBIG] #2723422
12/12/19 11:18 AM
12/12/19 11:18 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
I run 295's in back and 245's in front on an e-body, "plenty" of clearance. I am not sure if the 3rd gen b-bodies are like e-bodies where the spring cuts into the wheel well or like earlier b-bodies where they don't.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: Pacnorthcuda] #2723443
12/12/19 01:00 PM
12/12/19 01:00 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Pacnorthcuda said. "275/60’s are a much safer bet, but not quite as wide of course, which sucks." The metric tires don't size up like the old designation. The 295 50 15 is kinda short at 26.6" tall.. The 275 60 at 28" has the height but could use more width. The old N 50 15 was around 28" and a solid 12" wide at the tread. I like RWL tires but would love a RWL non drag race radial in a 325 50 15.
Keep old mopars alive.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: migsBIG] #2723850
12/13/19 09:14 PM
12/13/19 09:14 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I think the 275/60 would fill the profile better in the large wheel opening.The 295 is nice and wide but is definitely short looking.We have used the 295/50-15 on a 10" wheel on a '69 Plymouth GTX and it fit for the most part.Minor rubbing on the extreme curbs.The short tire isn't as noticeable on the more shielded quarter opening of the Plymouth.
RT
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: RTSrunner] #2723851
12/13/19 09:20 PM
12/13/19 09:20 PM
I’ve often thought the best tire size would be a 285/55/15.......if only we could just order em up!
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: RTSrunner] #2723901
12/14/19 01:09 AM
12/14/19 01:09 AM
San Jose,CA
San Jose,CA
RT
That sounds like something I should check for since I do like my cars to corner abit.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: migsBIG] #2723914
12/14/19 04:57 AM
12/14/19 04:57 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
For "stock" look... all 4 corners the same. Easier for everything ( rotation, replacement, emergency, whatever )
If you get SG, consider the tire size for the spare too. Myself ( I installed SG ) got a specific tire measure WHICH I CANNOT REMEMBER right now to match with 255/60 diameter, not being 255 wide but stockish look wide on stock steel wheel to get a comfortably fitment and look on trunk space, not a wide tire into the trunk.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: migsBIG] #2723924
12/14/19 08:28 AM
12/14/19 08:28 AM
GMP440 Offline
GMP440  Offline
A good friend of mine runs 305 50-15 on the back of 74 Charger. His rims are the same dimensions as yours. I can't remember if his offset was 4" or 4.5".
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: Pacnorthcuda] #2723930
12/14/19 09:26 AM
12/14/19 09:26 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Theyre are alot more variety of sizes in a non RWL type tire but I would like a Traditional N50x15 sized raised white letter BF Goodrich TA Radial.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: 2boltmain] #2723982
12/14/19 01:11 PM
12/14/19 01:11 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I recommend my 1.25" offset spring hanger/shackle kit, '68-'70 B-body rearend, 15 x 10" wheels with 5" backspacing and MT Sportsman SR 28/12/15 street radials.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: DoctorDiff] #2724347
12/15/19 11:26 PM
12/15/19 11:26 PM
Cumberland, MD
Moparguy383 Offline
Moparguy383  Offline
Cumberland, MD
I have a Dr. Diff offset spring hanger/shackle kit, '71 housing, 15 x 10 wheels with 5" backspacing and 325/50/15. Plenty of clearance.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: Moparguy383] #2724349
12/15/19 11:32 PM
12/15/19 11:32 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Boy does that look good !!
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: hemienvy] #2724380
12/16/19 07:13 AM
12/16/19 07:13 AM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
NICE!
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: jvcuda] #2724438
12/16/19 11:58 AM
12/16/19 11:58 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Migs,I have 295/50/15s on 15x10 Dragstars on my 73 Charger.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: migsBIG] #2724534
12/16/19 04:06 PM
12/16/19 04:06 PM
Chicago, IL
moe318 Offline
moe318  Offline
Chicago, IL
Wasn't there a write up on a Gunmetal gray 71 charger? It was an original paint grandma's car, pictures and measurements were given in a thread,for custom rims and tires.The end result was a well balanced good looking car.I don't remember the website,thought it was moparts? Also thought its pic was in a magazine as a survivor/upgrade??
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: Moparguy383] #2724563
12/16/19 05:34 PM
12/16/19 05:34 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Moparguy383 is that body raised? If so how much?
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: NachoRT74] #2725216
12/18/19 09:44 PM
12/18/19 09:44 PM
San Jose,CA
San Jose,CA
That does sound like a good idea. I don’t mind having an extra spare in the trunk as the trunks on these cars are huge and have a lot of capacity.
Thanks everyone for the help. Taking a few days to reply, dang Christmas time is super busy out here.
