‘72-‘80 D/W Pickup Metal Headliner Removal? #2723867
12/13/19 10:17 PM
12/13/19 10:17 PM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
Hello. I have a 1974 W200 Power Wagon.
Can and/or how is the Metal Headliner removed from inside the cab? I would like to work on a few dents and access/push them out from inside the cab.
Re: ‘72-‘80 D/W Pickup Metal Headliner Removal? [Re: D_C] #2723883
12/13/19 11:02 PM
12/13/19 11:02 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
it appears that you're just seeing the inside skin of the cab. No detachable headliner.
The trucks that had headliners had clips that attached a fiber-board backed headliner
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: ‘72-‘80 D/W Pickup Metal Headliner Removal? [Re: shanker] #2723886
12/13/19 11:15 PM
12/13/19 11:15 PM
D_C Offline OP
D_C  Offline OP
Thanks for the reply.
The Roof is definitely double-walled construction (inner and outer roof panels).
So does that mean there is no way to remove the inner shell short of cutting it out?
Thanks.
Re: ‘72-‘80 D/W Pickup Metal Headliner Removal? [Re: D_C] #2723922
12/14/19 08:11 AM
12/14/19 08:11 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
If you can't reach the dents from the visor holes or cargo light hole then you'll have to pull them out.
Re: ‘72-‘80 D/W Pickup Metal Headliner Removal? [Re: redraptor] #2724015
12/14/19 04:24 PM
12/14/19 04:24 PM
D_C Offline OP
D_C  Offline OP
So, the inner panel is crimped or soldered or welded to the cab...
When someone replaces the roof panel entirely, then they need to deal with the inner panel too I guess.
The roof has lots of small dents (as purchased) and would be easier to work from both sides, but I guess paintless dent repair and weld-on studs (plus a little body filler) will need to do the job.
Thanks.
DC
Re: ‘72-‘80 D/W Pickup Metal Headliner Removal? [Re: D_C] #2724038
12/14/19 06:46 PM
12/14/19 06:46 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Well, hey there, D C. wave Very long time, no see. How's the Charger?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: ‘72-‘80 D/W Pickup Metal Headliner Removal? [Re: I_bleed_MOPAR] #2724098
12/15/19 02:39 AM
12/15/19 02:39 AM
D_C Offline OP
D_C  Offline OP
Still have it, though the paint has deteriorated a bit.
I also own an airplane (Beech Bonanza) that eats up most of my free time and $$$.
In addition, have had a couple V8 CJ5 Jeeps (since the 1990’s) and bought this ‘74 Dodge Power Wagon 5-years ago. Took the trans out to rebuild 4-years ago, and it’s sat on the work bench since, though I’m finally working on it again.
Hope you’re doing well too.
DC
Re: ‘72-‘80 D/W Pickup Metal Headliner Removal? [Re: D_C] #2724135
12/15/19 10:54 AM
12/15/19 10:54 AM
Buford, GA
Buford, GA
Doing good. up Retired a few years back. Son still has the '71 Charger. Your pic didn't show up last night for some reason. My first new vehicle was a '74 W100 in light green. Looks like yours is the same color. boogie
Tim
'71 Charger 383/727
Re: ‘72-‘80 D/W Pickup Metal Headliner Removal? [Re: I_bleed_MOPAR] #2724421
12/16/19 10:52 AM
12/16/19 10:52 AM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
Did mine last summer. Cut the top skin. I had major rust issues on the front of the cab. My buddies shop found a real nice skin. He also cleaned up the inner panel and laid in some Raptor.
Abe Lincoln
Re: ‘72-‘80 D/W Pickup Metal Headliner Removal? [Re: I_bleed_MOPAR] #2725285
12/19/19 01:50 AM
12/19/19 01:50 AM
D_C Offline OP
D_C  Offline OP
Thanks for the replies.
Good to know.
My ‘74 W200 was first sold as a Pacific Telephone Utility truck but had a utility truck bed at a minimum. It may have been a bucket-truck
The paint....guessing it was originally White (engine bay, roof, etc) but the interior was green and the lower body Pacific Telephone Green as well, so two-tone green and white. A subsequent owner swapped on a standard 8-foot Sweptline bed.
When I received it, pretty rough looking, no front bumper, mangled step rear bumper, no Tailgate, no defroster grill, etc. Still has quite a way to go before I consider it acceptable, but getting the Trans rebuilt and re-installed is priority one.
This is what it looked like when I bought it in 2014, and more recently.
