Re: Question for Amsoil racing oil users [Re: hemi471] #272369
04/02/09 01:56 PM
04/02/09 01:56 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
What Amsoil says is that the oil is good for 25000 miles. You change to their oil and filter, and when you reach 12500 miles you replace the filter and add a quart of oil, then drive another 12500 and your ready for a complete oil change. If you are using the by-pass filter along with a full-flow filter and have a oil sample checked in the lab you still change the filters and add oil put you dont change the oil untill the sample does not pass.
The oil filters you are referring to is outdated filtration technology.
Consider the sequence of events below:
1st) Donaldson Company Selected to Develop Filtration System for U.S. Army Abrams-Crusader Common Engine Program - Article link
2nd) Go Twice the Distance With Donaldson Endurance™ Air Filters - pdf link
3rd) AMSOIL® Introduces Donaldson Endurance™ Air and Oil Filters with Nanofiber Technology - Press Release link
4th) AMSOIL Ea Oil Filters (EaO) - Data link
5th) AMSOIL Ea Air Filters (EaA) - Data link
CompSyn
Re: Question for Amsoil racing oil users [Re: CompSyn] #272370
04/02/09 03:53 PM
04/02/09 03:53 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
Yes you are right, the new EaO filters are good for 25000. I am still using the the old SDF filters till I run out Thanks!
Re: Question for Amsoil racing oil users [Re: hemi471] #272371
04/02/09 04:19 PM
04/02/09 04:19 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Well I worked in a Freightliner dealership back in 93/94. When the N14 cummins engine came out in the trucks. Cummins sent out a bulletin on extended oil changes. It provided that those companies who used oil analysis could go to 30,000 miles intervals with Mobil 1. Jim
Re: Question for Amsoil racing oil users [Re: rt66jim] #272372
04/02/09 05:06 PM
04/02/09 05:06 PM
Idaho
Runner Offline
Runner  Offline
Idaho
the company i work for has 17000 trucks and we have been running non synthetic oil at 30000k oil change intervals for at least 15 years. no warrenty issues with cummins, volvo, or detroit.
Re: Question for Amsoil racing oil users [Re: rt66jim] #272373
04/02/09 05:27 PM
04/02/09 05:27 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Sure! The Tri-Synthetic formula of 1990s. Mobil 1s current SuperSyn formula that was introduced in 2002 has been under a lot fire lately for higher levels of Iron found in UOA reports. See also this Iron in M1 UOA’s? - link
And then there are these links below:
Valvoline letter to Mobil 1 – link
Valvoline charges Mobil 1 does not meet current API specs. – link
Sequence IVA Cam Lobe Wear Test – Mobil 1 fails – link
CompSyn
Re: Question for Amsoil racing oil users [Re: Runner] #272374
04/02/09 05:35 PM
04/02/09 05:35 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Do those trucks come with by-pass oil filters on them?
Well, that is impressive - 30,000-miles on conventional oil. So how does 409,000-miles hit ya?
409,000-mile Mack E7-400 engine teardown – link
Imagine the tens of thousands your company could save with that…
CompSyn
Re: Question for Amsoil racing oil users [Re: CompSyn] #272375
04/02/09 08:41 PM
04/02/09 08:41 PM
Idaho
Runner Offline
Runner  Offline
Idaho
Anthony, yes bypass filters. we were looking at going to a synthetic blend and upping our oil change to somewhere around 60k as i remember but for what ever reason it didnt happen.
i really have no opinion one way or the other on oils. i run the oil i run because thats what the guy that i bought my cam from recomended. and im gun shy after i lost the cam in my 383 that had been in the car for 10 years.
Brad sorry for getting off track.
Re: Question for Amsoil racing oil users [Re: Runner] #272376
04/02/09 09:01 PM
04/02/09 09:01 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Mike, I'd be curious to learn more about your cam failure. I'll P.M. you about that though.
I'll also post this Technical Service Bulletin pdf with regards to Flat Tappet and Camshaft Lobe Lubrication - click HERE
CompSyn
