Re: 383 oil pump ?
[Re: stumpy]
#2723148
12/11/19 01:28 AM
12/11/19 01:28 AM
Posts: 2,904 Pattison Texas
CSK
Pattison Texas
HV pump, the newer HV pumps come with a high pressure spring, you have a stock type pump.
Re: 383 oil pump ?
[Re: roy282]
#2723180
12/11/19 09:21 AM
12/11/19 09:21 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
Thanks for reply, but not what I was hoping to hear, thought maybe it was a high volume aftermarket oil pump Thanks,
Rob
If you're running a stock oil pan and your oil clearances aren't on the loose side, then a stock type pump is what you want.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: 383 oil pump ?
[Re: an8sec70cuda]
#2723287
12/11/19 05:17 PM
12/11/19 05:17 PM
Posts: 115 Canada
roy282
Canada
Thanks for your reply's the 383 hp motor I picked up came with this oil pan and windage tray plus the aftermarket carter performance fuel pump so I thought maybe the oil pump was hv?Is there a way to tell by taking it off?
Mancini Racing B/RB 5 Qt Oil Pan
Fits: Big Block, B/RB
5 quart oil pan is based off Chrysler "971" Stamping. fits
Rear Main Seal Style: 2-piece
Sump Location: Center
Stroker Clearanced: No
Maximum Stroke with OE Rod: 3.750 in.
Sump Style: Wet
Oil Pan Capacity: 5.00 quarts
Oil Pan Depth (in): 5.250 in.
Oil Pan Material: Steel
Oil Pan Finish: Natural
Baffled: Yes
Kicked Out: No
Dipstick Provision: Yes
Windage Tray Included: No
Pickup Included: No
Crank Scraper Included: No
Drain Plug Thread Size: 1/2-20 in.
Gaskets Included: No
Hardware Included: No
Thanks Rob
Re: 383 oil pump ?
[Re: roy282]
#2723291
12/11/19 05:27 PM
12/11/19 05:27 PM
an8sec70cuda
The thickness of the pump body is how you tell if it's a high volume pump or not. Your pump appears to be about 1/4" shorter than the HV pump pictured above, so yours would be a standard volume pump. Like I said, not a bad thing and it's likely all it needs.
Re: 383 oil pump ?
[Re: roy282]
#2723307
12/11/19 06:09 PM
12/11/19 06:09 PM
CSK
Pattison Texas
Awesome thanks for your reply's!! always learning!!! also the picture of that engine, there is not a windage tray installed
Re: 383 oil pump ?
[Re: CSK]
#2723318
12/11/19 06:28 PM
12/11/19 06:28 PM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
Awesome thanks for your reply's!! always learning!!! also the picture of that engine, there is not a windage tray installed And it does not look like a new pan.
Re: 383 oil pump ?
[Re: Stanton]
#2723436
12/12/19 12:21 PM
12/12/19 12:21 PM
Posts: 18,025 S.E. Michigan
ZIPPY
S.E. Michigan
971 came with baffles front and rear, 5 quarts plus filter nominal fill, to my way of thinking that's actually not a horribly bad street performance kind of a piece.
The pump just looks like a stock piece but that's okay, if this is a stock-ish kind of a build I'd add a windage tray and that's about it,
Rich H.
Esse Quam Videri
