Re: 383 oil pump ?
[Re: stumpy]
#2723148
12/11/19 01:28 AM
12/11/19 01:28 AM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
HV pump, the newer HV pumps come with a high pressure spring, you have a stock type pump.
Re: 383 oil pump ?
[Re: roy282]
#2723180
12/11/19 09:21 AM
12/11/19 09:21 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Thanks for reply, but not what I was hoping to hear, thought maybe it was a high volume aftermarket oil pump Thanks,
Rob
If you're running a stock oil pan and your oil clearances aren't on the loose side, then a stock type pump is what you want.
Re: 383 oil pump ?
[Re: an8sec70cuda]
#2723287
12/11/19 05:17 PM
12/11/19 05:17 PM
Posts: 115 Canada
roy282
Canada
Thanks for your reply's the 383 hp motor I picked up came with this oil pan and windage tray plus the aftermarket carter performance fuel pump so I thought maybe the oil pump was hv?Is there a way to tell by taking it off?
Mancini Racing B/RB 5 Qt Oil Pan
Fits: Big Block, B/RB
5 quart oil pan is based off Chrysler "971" Stamping. fits
Rear Main Seal Style: 2-piece
Sump Location: Center
Stroker Clearanced: No
Maximum Stroke with OE Rod: 3.750 in.
Sump Style: Wet
Oil Pan Capacity: 5.00 quarts
Oil Pan Depth (in): 5.250 in.
Oil Pan Material: Steel
Oil Pan Finish: Natural
Baffled: Yes
Kicked Out: No
Dipstick Provision: Yes
Windage Tray Included: No
Pickup Included: No
Crank Scraper Included: No
Drain Plug Thread Size: 1/2-20 in.
Gaskets Included: No
Hardware Included: No
Thanks Rob
Re: 383 oil pump ?
[Re: roy282]
#2723291
12/11/19 05:27 PM
12/11/19 05:27 PM
an8sec70cuda
The thickness of the pump body is how you tell if it's a high volume pump or not. Your pump appears to be about 1/4" shorter than the HV pump pictured above, so yours would be a standard volume pump. Like I said, not a bad thing and it's likely all it needs.
Re: 383 oil pump ?
[Re: roy282]
#2723307
12/11/19 06:09 PM
12/11/19 06:09 PM
CSK
Pattison Texas
Awesome thanks for your reply's!! always learning!!! also the picture of that engine, there is not a windage tray installed
Re: 383 oil pump ?
[Re: CSK]
#2723318
12/11/19 06:28 PM
12/11/19 06:28 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Awesome thanks for your reply's!! always learning!!! also the picture of that engine, there is not a windage tray installed And it does not look like a new pan.
Re: 383 oil pump ?
[Re: Stanton]
#2723436
12/12/19 12:21 PM
12/12/19 12:21 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
971 came with baffles front and rear, 5 quarts plus filter nominal fill, to my way of thinking that's actually not a horribly bad street performance kind of a piece.
The pump just looks like a stock piece but that's okay, if this is a stock-ish kind of a build I'd add a windage tray and that's about it,
Rich H.
Esse Quam Videri
Re: 383 oil pump ?
[Re: roy282]
#2723649
12/13/19 08:32 AM
12/13/19 08:32 AM
BSB67
Prospect, PA
Thanks ZIPPY That's what I thought about the pan a little better then stock so I restored it.Not building a race car just a nice cruiser...
cheers Rob Cool car.
