Bearing experts?? #2722367
12/07/19 06:27 PM
12/07/19 06:27 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Any ideas what's going on here? Front to back. Lefty to right.. This is out of my 500" turbo motor . Stock 440 block stock caps. The mains look good except the thrust bearing. The thrust faces look pretty much untouched. The rear 4 rod bearings damage I would say probably from the junk that got pumped through it at the end. Just some scratching.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Bearing experts?? [Re: HOTMOPR] #2722369
12/07/19 06:32 PM
12/07/19 06:32 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Not sure how many passes it has but it hasn't been apart some 2011. Been running 12-16ish psi
Re: Bearing experts?? [Re: HOTMOPR] #2722373
12/07/19 06:39 PM
12/07/19 06:39 PM
I would check the crank for run out to see on the all the main bearing surfaces to see if it is bent or not scope
I don't like to see any run out at all on any of the mains twocents
EDITED, look real closely for cracks in the main webbing between the bottom of the block cylinder walls down into the main webbing also scope I'm not trying to alarm you but better to find it, any problems, now instead of running over the crankshaft later work shruggy
Re: Bearing experts?? [Re: Cab_Burge] #2722379
12/07/19 06:49 PM
12/07/19 06:49 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Ok thanks Cab. This motors race days are done. I am building a new short block for the race car. This 500 will be going in my 63 for street duty. unless the block is cracked.. lol. Ill pull the crank and get it checked too
Re: Bearing experts?? [Re: HOTMOPR] #2722437
12/07/19 11:58 PM
12/07/19 11:58 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm not fluent in oil flow paths on a BBM but is there any way flow can be restricted to #3 main and the front rods progressively worse front to back without scorching #1 & 2 mains? If the crank was bent I would expect at least one of the other mains to be showing some signs of stress. That one rod bearing closest to the thrust looks like it was about to go knock knock come out.
Kevin
Re: Bearing experts?? [Re: Twostick] #2722452
12/08/19 01:27 AM
12/08/19 01:27 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
ya there was a ton of build up around the dowel. Luckily it didt spin. Crank still looks great! Or great enough for me .. lol
Re: Bearing experts?? [Re: HOTMOPR] #2722498
12/08/19 11:21 AM
12/08/19 11:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
To me it looks like the clearance was tight. When I say clearance, we've found when the crank moves those particular bearings need to be looser. The number 3 main only feeds one (#4) of the "bad rod" bearings. Maybe some taper in the #1 rod journal as well. Are all the journals the same diameter and straight? all the rod bores the same and round. Are all the rods still straight? How much clearance did they have? That's what I would be checking. My sons turbo 360 cast crank pics on the #4 main. That main runs now slightly over.004". Our bet is the cast crank looks like a jump rope under boost.
Doug
Re: Bearing experts?? [Re: dvw] #2722548
12/08/19 01:39 PM
12/08/19 01:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What oiling system? How much pressure-volume? Driver side lifter galley blocked or lifters bushed? Reason, sometimes oil velocity is so much it goes by the down line to the mains if there’s big oil bleed off in the system. Those mains look oil starved
Re: Bearing experts?? [Re: HOTMOPR] #2722579
12/08/19 04:43 PM
12/08/19 04:43 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
My best guess is you are starving it for oil on the launch.
Middle sump pan?
Oil climbs to the rear of the engine and splash oils the rear half of the rotating assy.
Are you logging oil pressure?
Re: Bearing experts?? [Re: TRENDZ] #2722581
12/08/19 04:54 PM
12/08/19 04:54 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Yes center sump road race pan. Running 8 quarts. All the baffles are cut out. Has a single line Milodon pickup. Logs show 70-75 psi whole run.
Re: Bearing experts?? [Re: HOTMOPR] #2722613
12/08/19 06:46 PM
12/08/19 06:46 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Hmmm. Stumped.
Re: Bearing experts?? [Re: HOTMOPR] #2722614
12/08/19 07:10 PM
12/08/19 07:10 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I miss read your post
Re: Bearing experts?? [Re: Clanton] #2722628
12/08/19 07:52 PM
12/08/19 07:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The reason I didn't mention starvation is that not all the bearings reflect that. Normally starvation shows up towards the rear bearings 1st. Not the case here.
Doug
Re: Bearing experts?? [Re: TRENDZ] #2722652
12/08/19 09:35 PM
12/08/19 09:35 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Why is it apart? Were there symptoms? Im surprised the logs never showed a change.
Re: Bearing experts?? [Re: TRENDZ] #2722658
12/08/19 10:15 PM
12/08/19 10:15 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Building a new short block. I was checking bearings after the beating this block has taken. This combo has been 138-140 mph in the 1/8th mile at 3550 pounds so it been making some power I was expecting main bearing damage but not much rod bearing issues. Was planning to throw a different cam and heads on it and roll some new bearing in it. Then run it in my street car.
Re: Bearing experts?? [Re: HOTMOPR] #2722659
12/08/19 10:20 PM
12/08/19 10:20 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
I did notice some light bearing material in my K&P when I was creeping up on 18 psi. So I turned it down for the last race. Assuming it was main bearing material. That's the main reason I pulled caps. As for logs there was zero change in oil pressures throughout the year.
Re: Bearing experts?? [Re: HOTMOPR] #2722872
12/10/19 04:18 AM
12/10/19 04:18 AM
I think the #3 main bearing trash mostly went into #4 rod and some of that material may have been caught a tiny bit by #3 rod work
I'm really surprised that none of the main bearing trash from the center main bearings wasn't wash into #5 rod bearing also confused
Did the motor have at least .0040 or more thrust clearances new?
Was #3 main bearing straight with no taper front to rear on the clearances?
I've seen between .0002 to .0004 taper on some of the new main bearings with block that had been align honed with new main caps and studs shockwork
Re: Bearing experts?? [Re: Cab_Burge] #2722880
12/10/19 08:33 AM
12/10/19 08:33 AM
ON
GTSocker Offline
GTSocker  Offline
ON
I'm guessing you are starving for oil on deceleration. Maybe rethink your oil pan and pick up??
Re: Bearing experts?? [Re: GTSocker] #2722933
12/10/19 12:37 PM
12/10/19 12:37 PM
Fort Collins, Colorado
CoDart Offline
CoDart  Offline
Whats your engine/turbo combo? Sounds like its making some decent steam for sure!
Re: Bearing experts?? [Re: CoDart] #2723068
12/10/19 07:49 PM
12/10/19 07:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
These are my questions. Why would the #3/4 rod and #3 main be hit the worst? Is the main web cracked? If there was lack of oil feed to the #3 main the #5 rod should show wear as well. #3/4 are not last in line for oil. What was the bearing clearance? Are the journals round and straight? Is the crank cracked?
Doug
