Re: issues with fresh 440
[Re: stinger]
#2722391
12/07/19 08:03 PM
12/07/19 08:03 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Did you cut the filter apart. It’s a very good thing to do after cam break in.
[Re: Wax]
#2722403
12/07/19 08:48 PM
12/07/19 08:48 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Hard to tell by looking at a pic on my phone, but I don’t see anything alarming on the cam. Pull each lifter and carefully inspect the bottom of it.
When cam lobes go bad, the lifters almost always go with them. With as little run time as it has, the lifters should be perfect. If you see something iffy on one, carefully inspect the corresponding cam lobe.
Did you check for lifter rotation during assembly? What are the open and closed spring loads? What did you use for cam lube?
[Re: stinger]
#2722408
12/07/19 09:09 PM
12/07/19 09:09 PM
Posts: 2,867 Pattison Texas
CSK
Pattison Texas
[Re: CSK]
#2722411
12/07/19 09:30 PM
12/07/19 09:30 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Is it the camera flash or shop lighting that makes some of the lobes look shinier than others?
[Re: B1MAXX]
#2722501
12/08/19 11:44 AM
12/08/19 11:44 AM
fast68plymouth
So. Burlington, Vt.
The nose of the cam lobes will have contact all the way across.
It’s extremely unlikely all the lobes are going flat, so turn the motor over by hand so you can inspect the nose of each lobe. You’re looking for one that’s obviously different than the others.
To address the oil pressure, I agree with pulling the pump all apart, clean and inspect. Actually, before you pulled the pump, you could remove and inspect how smoothly the relief valve slides in its bore.
As for the noise, I think you’d be better off with more preload. 1/2 to 1 turn....... depending on the thread pitch of the adjuster screw. I’d be shooting for .030-.040 preload.
[Re: lewtot184]
#2722556
12/08/19 02:17 PM
12/08/19 02:17 PM
Posts: 1,237 North Central, Indiana
Roughbird72
1/4 turn isn't near enough pre-load on the tappets. at a 24 thread that's roughly .010 - .012
72 Plymouth Roadrunner 11.08@123.25
[Re: stinger]
#2722582
12/08/19 05:00 PM
12/08/19 05:00 PM
fast68plymouth
So. Burlington, Vt.
#6 exhaust lifter face is slightly concave but no marks on it. Let’s see a pic....... but....... it’s done. What starts out as slightly concave becomes:
[Re: lewtot184]
#2722596
12/08/19 05:53 PM
12/08/19 05:53 PM
fast68plymouth
So. Burlington, Vt.
I’ll add that if the cam being used is a Purple Plus 509 cam, those use .904 lifter diameter lobes. Sometimes the factory lifter bore positioning is such that a .904 specific lobe has the profile running off the edge of the lifter.
“If it were me”, I would use a cam that had a lobe profile that didn’t require .904 lifters.
Assuming the PP509 was a good match for the overall combo, something like a 21-314-4 would provide for a similar powerband and “character”, but doesn’t require the .904 lifter. You’d possibly be giving up a few ponies.
An Isky 292 Mega-cam would be another option, along with the Howard’s Big Daddy Rattler.
All of those recommendations assume you’re running headers.
