Regarding 1958 350 B engines #2722257
12/07/19 11:18 AM
12/07/19 11:18 AM
Nebraska
451Cuda Offline OP
451Cuda  Offline OP
Nebraska
I may be getting a 350 B engine soon, since it's pretty cheap, but wanted to know a few things about it before I take a trip.
Is the crank 6 bolt or 8 bolt?
Same journals as 361/383/400?
I assume it's a forged crank, is it just as strong as later B's?
Are counterweights light enough that it won't balance in a 383?
I figured the block wouldn't have the material for a 4.25 bore...am I wrong?
Rods the same as later B's?
Thanks in advance for any info on this...can't find any with Google searches, only find what it was in and hp levels, nothing this specific.
Re: Regarding 1958 350 B engines [Re: 451Cuda] #2722283
12/07/19 12:50 PM
12/07/19 12:50 PM
iowa
copchaser Offline
copchaser  Offline
iowa
8 bolt extended crank, same journals, rods. etc. Very small bore. Interesting piece to own, and that's about it. Better have the block sonic checked, and custom pistons will be required. If you pass on it. I'd be real interested in it. As well as a RB 383.
Re: Regarding 1958 350 B engines [Re: copchaser] #2722291
12/07/19 01:27 PM
12/07/19 01:27 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the extended crank would be my concern. whether this is a problem or not will depend on the trans/chassis used.
Re: Regarding 1958 350 B engines [Re: 451Cuda] #2722364
12/07/19 06:26 PM
12/07/19 06:26 PM
I wouldn't mess with that motor, Mopar only made it one year and then moved up to the 361.383 and 413 motors work
