Sixpack balancer numbers "?" #272160
03/31/09 12:14 AM
03/31/09 12:14 AM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
I have a Sixpack balancer with some small numbers stamped on the inner / outside edge of the balancer
63620
0159
Can anyone explain / identify these numbers to me? I thank you in advance
Re: Sixpack balancer numbers "?" [Re: kidmopar] #272161
03/31/09 12:20 AM
03/31/09 12:20 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I haven't noticed any numbers on the '70-'71+ 440 "heavy rod" balancers. Can you post a pic?
Re: Sixpack balancer numbers "?" [Re: 6bblgt] #272162
03/31/09 12:24 AM
03/31/09 12:24 AM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Go to the 440Source site here in the sponsor section. They have all the info you need (and some you don't) on their site.
Re: Sixpack balancer numbers "?" [Re: Classof70Chally] #272163
03/31/09 12:33 AM
03/31/09 12:33 AM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
I did look @ "440source" and they had part #'s however no reference to the little stamped numbers I've posted I'm going to take a couple photos & post them. ( should have done that anyway , Huh? )
Re: Sixpack balancer numbers "?" [Re: kidmopar] #272164
03/31/09 04:04 PM
03/31/09 04:04 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
63620
0159
I have seen date code numbers on several steel
crank 383/440 dampers, or what I believe to be date
code numbers. 0159 I take this to mean 15th
day of 1969.
logan426
Re: Sixpack balancer numbers "?" [Re: 6bblgt] #272165
03/31/09 09:44 PM
03/31/09 09:44 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
Here's a couple of photos of what I was talking about.
Re: Sixpack balancer numbers "?" [Re: kidmopar] #272166
03/31/09 10:41 PM
03/31/09 10:41 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
It may be off an A12 but it's the same as a regular 440 balancer. Other than the date code it's not special like the 70-71 sixpack balancer
Re: Sixpack balancer numbers "?" [Re: RoadRunnerJD] #272167
04/03/09 07:24 PM
04/03/09 07:24 PM
NJ
moparply Offline
moparply  Offline
NJ
The top numbers would be the vender number. The lower numbers would be the date code.
