Cleaning new Molnar rods results
#2720365
11/29/19 11:22 PM
11/29/19 11:22 PM
Posts: 43,240 Bend,OR USA
Cab_Burge
I'm rebuilding a 440 stroker motor for one of my local customers, it had a older 4.150 440 Source stroker kit in it assemble by another local Mopar racer a bunch of years ago. It spun a rod bearing(not badly) so I suggested having the crankshaft magnafluxed and if it magged good to resuse it by offset stroking the rods down to BB Chevy rod journal size and increase the stroke as much as we could get. It ended up with a 4.322 stroke, I ordered a se off Molnar 7.100 long BB Chevy type rods and a set of CP pistons to match this motor pistons through them I normally disassemble and clean the rods in my solvent tank and then blow dry them and reclean them with brake cleaner and blow dry them again. It snowed here early this week and the outside air temps haven't been above 25F during the day and my shop where the solvent tank is right at 50F so I decided to use a small amount of solvent in a small steel oil drain pan and hand clean them with brushes, I use two pans and put 4 rods apart in the one without solvent and clean the other four in the pan with solvent. I'm amazed how much gunk was washed off those eight rods They looked like the shop I had balance and check both ends ran them through a spray washer when they where done so maybe some of that gunk is from them My main message is to clean them and every thing else that goes into the motor, NEVER ASSUME they(any parts) are clean enough to use brand new
Re: Cleaning new Molnar rods results
[Re: Cab_Burge]
#2720406
11/30/19 10:30 AM
11/30/19 10:30 AM
Posts: 4,209 New York
polyspheric
New York
Thanks.
This wound up a multi-million dollar medical malpractice lawsuit years ago. The manufacturer of some artificial joints (hip, femur ball) used chemical wash to sterilize them, and they were inserted in the patient without secondary inspection (supplied in sealed, single use packaging). Yes, the cleaning fluid was still there, and infected the wound - the whole thing had to be done over again, in some cases the patients suffered permanent disability.
I shiver every time I see someone handle freshly machined & cleaned engine parts with bare hands. This was known to be a problem 80 years ago: some corrosion developed in critical weapon manufacture (WWII), and it was traced to... assembly line workers with red hair. Their skin oil (transferred through their fingerprints) was highly acidic compared to other workers. Re-purposed them to another line: problem solved.
No such thing as too clean.
Boffin Emeritus
[Re: polyspheric]
#2720411
11/30/19 10:52 AM
11/30/19 10:52 AM
Posts: 2,663 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Thanks.
Yes, I believe the lawsuit you are talking about is the one where the spec said to ultrasonic clean them and they didn't. They saved $1 per part. It's hard to believe that invisible oil can cause such a problem but then the glue wouldn't stick. Made those peoples lives miserable.
2011 Drag Pak Challenger
[Re: polyspheric]
#2720417
11/30/19 11:31 AM
11/30/19 11:31 AM
Posts: 4,457 Washington
madscientist
Washington
Thanks.
No such thing as too clean. Very interesting. I have been wearing latex gloves since the mid 1990's and everyone made fun of me when I started. It was mostly because I was having some medical issues and I just wanted to keep the solvent and everything else off my hands. I did notice very quickly how the parts and tools I handled and used never formed any spot stains or anything else. It wasn't long and everyone was wearing them.
[Re: merpar]
#2720442
11/30/19 01:38 PM
11/30/19 01:38 PM
Posts: 11,631 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Everyone has their own routine, for better or worse.
I had 2 parts washers. One to clean parts. The second had a good filter in it and was only used as a final rinse for previously cleaned parts. Lots of compressed air. Depending on the part, it may also have had a hot water rinse and blow dry.
Bearing inserts got lightly rubbed with fine scotchbrite. Washed multiple times. Wiped with acetone and blown off multiple times before they were assembled. Bearing journals were also wiped with acetone. Paper towels used exclusively, no cloth wipes. This eliminated the snotty wads of cloth fibers that would show up in the oil filter. You do look at your oil filter, right?
Everything got blown off with dry compressed air and maybe brakekleen to get the last bit of dust and lint, just before the assembly lube and assembly.
And don't forget to bag it while it's on the stand.
[Re: mopar dave]
#2720529
11/30/19 09:57 PM
11/30/19 09:57 PM
Cab_Burge
I forgot to mention that I used a brass wire bottle brush to get into the threads in the rods to remove the lube, anti rust what ever they used, out of the threads. Maybe some of the gunk I saw in the clean pan was from up in there I use lacquer (SP?) thinner on a pice of clean white cloth from a old cut up T shirt as my final cleaner on all steel, cast iron or any other metal surfaces like bearings to make sure I have not left any residue from my hands or fingers I do use motor oil only for bearing lube, no special assembly lubes for the engine start up, I always prime the motors first before starting also
[Re: Cab_Burge]
#2720535
11/30/19 11:29 PM
11/30/19 11:29 PM
polyspheric
New York
W/r/t/ serious cleaning products (Brake Kleen, MEK, acetone, lacquer thinner, Gun Scrubber): Do it outdoors, wear SCUBA, or hold your breath. No mask* filters out these solvents - cancer to follow in 5 years. * I've heard that activated charcoal is better than nothing, but no way to tell when it's saturated.
Boffin Emeritus
[Re: polyspheric]
#2720536
11/30/19 11:53 PM
11/30/19 11:53 PM
Cab_Burge
W/r/t/ serious cleaning products (Brake Kleen, MEK, acetone, lacquer thinner, Gun Scrubber): Do it outdoors, wear SCUBA, or hold your breath. No mask* filters out these solvents - cancer to follow in 5 years. * I've heard that activated charcoal is better than nothing, but no way to tell when it's saturated. I've had three different types of cancer, two types of skin cancer and Prostrate cancer, I quit handling Toulene and Toulol with my bare hands in the mid 1970s, I use to wash parts in my solvent tank without gloves I've used spray brake cleaner, spray carb cleaner as well as 5 gallon dip buckets of carb cleaners with no protection , I have use MEK, Acetone, Toulol and Toulene to mix with pure methanol alcohol with race gas back in the mid 1970s to make one of my old bracket cars go faster, it would pick up right at .3 ET and 2 MPH with 25% methanol and those other chemicals I used to keep it mixed with the race gas, some of the things we did before we knew better I first heard about Toulol and Toulene being a cancer causing chemical in the mid 1970s, I use to buy them both in five gallon containers from the local paint stores I am truly blessed that I didn't suffer worst results from those days, Thanks be To God To all on here, be careful and pay attention to what you put through and on your body, be safe
[Re: Cab_Burge]
#2720543
12/01/19 12:32 AM
12/01/19 12:32 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
NO ONE used gloves or respirators back then. And the solvents were better (worse from a health standpoint?). I'd wash parts with no gloves and my hands would look like gray parchment. Even the good carb dip solvent to some degree, but very much of that on you and you would soon be wanting to get it off, burned. Make a fist and the knuckles split and bleed. Hell, I was the guy in the parts washer, no gloves, scrubbing parts with a Kool in my mouth.
I suppose I'm lucky. Probably a few issues now related to that stuff, brake dust and some other crap, but nothing major (yet). Heck, I still use a little brakleen or acetone on towel to wipe crap off my hands when I don't want to stop and wash. And probably don't use gloves every time I should.
Don't be a tough guy or tight a$$. Use the PPE available to you.
[Re: Cab_Burge]
#2720568
12/01/19 08:30 AM
12/01/19 08:30 AM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
W/r/t/ serious cleaning products (Brake Kleen, MEK, acetone, lacquer thinner, Gun Scrubber): Do it outdoors, wear SCUBA, or hold your breath. No mask* filters out these solvents - cancer to follow in 5 years. * I've heard that activated charcoal is better than nothing, but no way to tell when it's saturated. I've had three different types of cancer, two types of skin cancer and Prostrate cancer, I quit handling Toulene and Toulol with my bare hands in the mid 1970s, I use to wash parts in my solvent tank without gloves I've used spray brake cleaner, spray carb cleaner as well as 5 gallon dip buckets of carb cleaners with no protection , I have use MEK, Acetone, Toulol and Toulene to mix with pure methanol alcohol with race gas back in the mid 1970s to make one of my old bracket cars go faster, it would pick up right at .3 ET and 2 MPH with 25% methanol and those other chemicals I used to keep it mixed with the race gas, some of the things we did before we knew better I first heard about Toulol and Toulene being a cancer causing chemical in the mid 1970s, I use to buy them both in five gallon containers from the local paint stores I am truly blessed that I didn't suffer worst results from those days, Thanks be To God To all on here, be careful and pay attention to what you put through and on your body, be safe I'm sure some of you remember ricxrt , use to post here , I helped him with his legal issues , some of the photos in his case, 30 years in the Coating industry . takes it's toll on the human body, some people their body chemistry can absorb high amounts, some people well genetics can be a b!tch.......over that time period (with masks and protective clothing) he's reached a toxicity level where certain chemicals react with his body chemistry. ........................So take care , be safe , PROTECT YOURSELF
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Twostick]
#2720608
12/01/19 11:47 AM
12/01/19 11:47 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some of the stuff we are exposed to on our jobs is crazy bad. In the steel mills asbestos was almost everywhere and we never had training on it till my last five years. We made primarily specialty steel and when we had to service our dust collectors we had to wear two trybex paper suits l, two pair of rubber gloves, plastic hoods, and full face respirators. Chromium, cyanide, lead, and many other chemicals while dealing with 120-180 temps in the dust collector compartments. Our body is remarkable
[Re: Cab_Burge]
#2720685
12/01/19 04:43 PM
12/01/19 04:43 PM
polyspheric
New York
And, as we all know, if you ever heard someone say "asbestos" Johns Manville owes you $1 billion. If those claims were true, every shipyard worker, plumber, sailor, etc. ever born died of it a hundred years ago. I remember that distinctly.
Next: another wave of "your vaccine gave my child autism".
Trust me: juries do not need proof of actual causation to award huge sums of money to someone who claims to be affected. These travesties persist because of the trial lawyers associations and insurance companies.
That can't be right, insurance companies HATE paying money. "Don't fling me in that briar patch!" Insurance premium rates are controlled by State agencies, they can recover only a fixed percent of their investment. Would you rather have 3% of $100 million, or 3% of $100 billion?
Boffin Emeritus
[Re: polyspheric]
#2721163
12/03/19 02:44 PM
12/03/19 02:44 PM
Posts: 8,306 fredericksburg,va
cudaman1969
fredericksburg,va
W/r/t/ serious cleaning products (Brake Kleen, MEK, acetone, lacquer thinner, Gun Scrubber): Do it outdoors, wear SCUBA, or hold your breath. No mask* filters out these solvents - cancer to follow in 5 years. * I've heard that activated charcoal is better than nothing, but no way to tell when it's saturated. Im 70 should be dead by now I guess or just good genes. I do where a mask when grinding-painting now, gloves too. I use the Nelly-pot nose rinse, what comes out of your nose-sinus will scare you.
[Re: Cab_Burge]
#2739979
02/05/20 01:53 PM
02/05/20 01:53 PM
Posts: 8 Alaska
Johnsnow Kornar
Alaska
W/r/t/ serious cleaning products (Brake Kleen, MEK, acetone, lacquer thinner, Gun Scrubber): Do it outdoors, wear SCUBA, or hold your breath. No mask* filters out these solvents - cancer to follow in 5 years. * I've heard that activated charcoal is better than nothing, but no way to tell when it's saturated. I've had three different types of cancer, two types of skin cancer and Prostrate cancer, I quit handling Toulene and Toulol with my bare hands in the mid 1970s, I use to wash parts in my solvent tank without gloves I've used spray brake cleaner, spray carb cleaner as well as 5 gallon dip buckets of best car upholstery cleaners with no protection , I have use MEK, Acetone, Toulol and Toulene to mix with pure methanol alcohol with race gas back in the mid 1970s to make one of my old bracket cars go faster, it would pick up right at .3 ET and 2 MPH with 25% methanol and those other chemicals I used to keep it mixed with the race gas, some of the things we did before we knew better I first heard about Toulol and Toulene being a cancer causing chemical in the mid 1970s, I use to buy them both in five gallon containers from the local paint stores I am truly blessed that I didn't suffer worst results from those days, Thanks be To God To all on here, be careful and pay attention to what you put through and on your body, be safe Have you been looking for the right cleaning agents to maintain your upholstery in the best shape and form at all times?
