Cam question Lopo 440 #2719289
11/25/19 08:08 PM
11/25/19 08:08 PM
Garry Owen Offline OP
Have a 77 440 that I’d like to cam. Been trying to read a lot here and other places and seem to find that the Hughes whiplash and comp xe262 are being used as a compression crutch. Maybe down the road I’ll pull the pistons and get something better but for now it’s a cam. The constants are a 3400 lbs car, auto, 3.23 gear. Right now it’s a stock bottom 440, ch4b intake, heads are 452’s but looking for some that flow better, and a 750 Holley. Stock 68 trans and converter. 3.23 Detroit locker with 27” tires.
Anyone used either one or have something better that they’re using? Also, this is just a cruiser so I’d rather not have it have to run in the upper rpms just more torque.
Re: Cam question Lopo 440 [Re: Garry Owen] #2719352
11/26/19 12:24 AM
11/26/19 12:24 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
crane 272 hmv 2 deg advanced
Re: Cam question Lopo 440 [Re: calrobb2000] #2719378
11/26/19 07:41 AM
11/26/19 07:41 AM
west palm beach, florida
modelmakerinc Online content
modelmakerinc  Online Content
right now the eddy E-street heads are on sale for 1200 pair and they have a $100 off promotion,(Jegs or Summit) the 75 cc angle plug the 84 cc straight plug, if you have headers that accept the angle plug you can bump compression by about a point plus have bigger valves and better flow
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Cam question Lopo 440 [Re: modelmakerinc] #2719402
11/26/19 10:16 AM
11/26/19 10:16 AM
Neenah,Wi
rod440 Offline
rod440  Offline
Neenah,Wi
Will the stock HP manifolds clear the angled plugs?
Re: Cam question Lopo 440 [Re: rod440] #2719407
11/26/19 10:30 AM
11/26/19 10:30 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
Re: Cam question Lopo 440 [Re: modelmakerinc] #2719430
11/26/19 11:54 AM
11/26/19 11:54 AM
I have hooker super comp headers so I'll have to check and see angle for plugs. I've been trying to find a happy medium on heads and cam. Either get the smallest cc head to raise compression a bit or stay at really low compression then find a cam that someone has had some experience with. I know quench is what to shoot for but it's not in the cards for a while.
Re: Cam question Lopo 440 [Re: Garry Owen] #2719590
11/26/19 10:44 PM
11/26/19 10:44 PM
So, is no one using either of these cams?
Calrobb, are you running that 272?
Re: Cam question Lopo 440 [Re: Garry Owen] #2719792
11/27/19 04:01 PM
11/27/19 04:01 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Specs on the Crane 272 cam are as follows... 218/228 duration at .050, .454/.480 lift, 112 center. I have not used this cam myself, but it looks like it would be a great cam for what you are wanting.
Re: Cam question Lopo 440 [Re: Garry Owen] #2719921
11/28/19 12:58 AM
11/28/19 12:58 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i run that cam in a 9.5 -1 440
good idle 16 in vac 12.5 et at 110 mph 3750 lbs !
headers an 3 in ex.
been in motor for 32 years !
lower comp add some advance 2 to 4 deg
Re: Cam question Lopo 440 [Re: calrobb2000] #2719968
11/28/19 09:44 AM
11/28/19 09:44 AM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
calrobb2000, what gears are you running in the rear end with that combo?
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: Cam question Lopo 440 [Re: Ray440] #2720010
11/28/19 11:29 AM
11/28/19 11:29 AM
moparx Offline
moparx  Offline
anyone remember the crane "fireball" cam series ?
what kind of specs did those have, or was that just a name crane put on their cams at that time ?
i remember them when they first came out, but the brain cobwebs ate everything but the name. biggrin
beer
Re: Cam question Lopo 440 [Re: moparx] #2720043
11/28/19 12:55 PM
11/28/19 12:55 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I have a vague recollection that the Fireball cams were Crane's "HMV" series (Hydraulic Maximum Velocity)? Or am I mixing up memories? work
Re: Cam question Lopo 440 [Re: DrCharles] #2720061
11/28/19 01:53 PM
11/28/19 01:53 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
My recollection was that the "fireball" was bigger than the "blazer", but smaller than the "commander". Of which there were two. Smaller and bigger. That's all I got.
Re: Cam question Lopo 440 [Re: Garry Owen] #2720074
11/28/19 02:23 PM
11/28/19 02:23 PM
I put a Comp Cams 260H grind( I think anyways (maybe it was the XE262 cam. work It was back in the early 2000s when I put that motor together to sell it) in a 383 motor or my 1969 Dart GTS 4 sped car. That cam has a very small lope and pulls hard form a dead idle all the way up to where I shift by sound, at WOT probably around 6000 RPM shruggy It works good up
Re: Cam question Lopo 440 [Re: calrobb2000] #2720161
11/28/19 10:09 PM
11/28/19 10:09 PM
Originally Posted by calrobb2000
hi
headers an 3 in ex.
More info?
Same, more info?
Re: Cam question Lopo 440 [Re: Ray440] #2720189
11/29/19 01:46 AM
11/29/19 01:46 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i now have 4.30 but i think car would be quicker with 4.10 , not enough cam for 4.30
3.55 got me to 12.7 - 109 mph
i used to drive it 58 miles to track and 58 miles back and make 8 passes on 1 full 16 gal tank of fuel with 3.55 . on E when i got home .
trailer it now .
torque is what you want , dont chase the hp number it mostly leads to disapointment .
Re: Cam question Lopo 440 [Re: DrCharles] #2720191
11/29/19 01:56 AM
11/29/19 01:56 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
most fireball had longer duration and not to much lift , not hmv cam
hmv came later . now called power max
crane has a 260 but if you do the compression upgrade later you will want the 272.
Re: Cam question Lopo 440 [Re: calrobb2000] #2720227
11/29/19 11:37 AM
11/29/19 11:37 AM
hi
trailer it now .
Torque is what I want. It’s not going to the track.
That’s why I originally asked about those cams. They “seem” make torque on a low compression engine.
I know it’s easy to go down a rabbit hole so I’m limiting myself to heads and a cam.
Re: Cam question Lopo 440 [Re: Garry Owen] #2720236
11/29/19 12:21 PM
11/29/19 12:21 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Bowl blend the 452’s, mill .030, correct intake side, use steel shim gaskets.
While they’re off, have them set up for posi valve seals and increase retainer to seal clearance....... upgrade springs.
However, if after pulling them apart, don’t be surprised if you see ex seat recession.
If your headers are angle plug friendly, and it’s in the budget..... the 75cc E Streets make a lot of sense.
Crower 271HDP cam
11” converter
Re: Cam question Lopo 440 [Re: fast68plymouth] #2720723
12/01/19 06:16 PM
12/01/19 06:16 PM
Crower 271HDP cam
11” converter
Looks like I might get the e-streets and the thinnest gasket. I haven’t pulled the heads and measured deck height but I used .140 and hoping it’s better than that. 8.8:1 is what I got in a calculator based off 75cc head, .027 gasket, and .140 in the hole piston.
I forgot to mention I have power brakes so I think that rules out the whiplash from what I’ve read. Also, 91 is the highest octane anywhere close. I still would rather not change out the converter and gears.
