Cleaning Parts before ASSY #272004
03/30/09 09:06 PM
03/30/09 09:06 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
How do you clean your block, crank, rods, pistons, cam, etc. before assymbling your engine?
I usually use dawn dish soap and the hottest water I can stand.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Cleaning Parts before ASSY [Re: DemonDust] #272005
03/30/09 09:23 PM
03/30/09 09:23 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Solvents only for me.
Never used water just because of the potential for rust.
Re: Cleaning Parts before ASSY [Re: Neil] #272006
03/30/09 09:34 PM
03/30/09 09:34 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I use solvents also
Re: Cleaning Parts before ASSY [Re: Neil] #272007
03/30/09 09:34 PM
03/30/09 09:34 PM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
brake cleaner and the cleanest lint-free rags I can find works well for me... I use the cheap stuff and am not afraid to waste some if I need to in order to get something clean.
Looking forward to more replies! Maybe I can save some $$$
Re: Cleaning Parts before ASSY [Re: Neil] #272008
03/30/09 09:36 PM
03/30/09 09:36 PM
Menomonee Falls
Menomonee Falls
How do you clean out the gallerys? Just with air?
SDG Motorsports
Re: Cleaning Parts before ASSY [Re: enelson] #272009
03/30/09 09:41 PM
03/30/09 09:41 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
old baby diapers...clean of course...and Pledge furniture polish...its designed to pick up dust and provides a nice lil barrier to moisture....learned that from a guy who used to work for Carol Shelby. ....now if were super cleaning and storing I know someone at a Raybesto caliper reman factory here in town and we take my stuff over...put it in the steam cabinet then it goes into a bath of Oakite(water soluable oil and hot water)...hey if calipers can stay freshly bead blasted in boxes for years...it MUST work...no rust here on a crank that was done 5 years ago and lays in a box on the floor under the bench.
Re: Cleaning Parts before ASSY [Re: Chassisman] #272010
03/30/09 09:59 PM
03/30/09 09:59 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
lint free rags are IMPORTANT.
I learned that the hard way when i lost oil pressure on my first engine build years ago. The lint actually washed into the pan from the towels i used and collected on the oil pickup. it looked just like the coating you see on a dryer lint screen. only oily
Re: Cleaning Parts before ASSY [Re: Chassisman] #272011
03/30/09 10:00 PM
03/30/09 10:00 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Use liquid laundry detergent, mix it very rich with lots, and lots of detergent, around 4:1 water/detergent, it will not rust, leaves a film that keeps from flash rusting. I run My engines for 15-20 minutes until operating temp are met, and change the oil and filter.
I use a siphon style blow nozzle with compressed air.
Old machinist told me this 20 years ago, have always done this and has never failed.
Blow dry after I suspect its clean enough, and wipe down with clean lent free paper towels..Leaves your hand nice and fresh
Re: Cleaning Parts before ASSY [Re: DemonDust] #272012
03/30/09 10:24 PM
03/30/09 10:24 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Engine brushes and lots of carb cleaner. If you rotate the engine around on the stand you can get gravity to assist with the cleaning too.
Air by itself can't clean much. You have to use the engine brushes in every hole pretty much.
Re: Cleaning Parts before ASSY [Re: Neil] #272013
03/31/09 09:04 AM
03/31/09 09:04 AM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Anyone use the dishwasher? I'm thinking of tossing all my stuff in. Any Objections?
Re: Cleaning Parts before ASSY [Re: Bubba] #272014
03/31/09 10:14 AM
03/31/09 10:14 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
The wife probably would not be to impressed
Here is my routine
Block gets the bores sprayed with WD-40 then pressure washed with hot soapy water.
Run pipe cleaners through the galleries . Poke the spray nozzle in all the crank and oil transfer hole and watch the water shoot out like a sprinkler. (At this time I am usually completely soaked also )
Rinse with hot water and wipe down bores with WD-40 and PAPER TOWELS
The crank goes to the solvent tank and gets violated in every hole with the pipe cleaner brushes.Blown dry with air and installed immediately.
Rods and pistons get the solvent tank then Castrol super clean in the bird bath and blown dry the installed .( steel rods I will just use solvent )
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Cleaning Parts before ASSY [Re: DemonDust] #272015
03/31/09 10:48 AM
03/31/09 10:48 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
Block, $5.00 at the local car wash, solvents, more soap and water.
White kerosine, and solvents till zero residue for everything else.
No shch thing as TOO clean.
Re: Cleaning Parts before ASSY [Re: JBurch] #272016
03/31/09 10:54 AM
03/31/09 10:54 AM
I have and it works great! Especially on parts like the main caps, rods and pistons.
I put it on the "Pots and Pans" setting and it tends to work the best. I've put really grimey stuff it and it came out clean.
It flash rusts the rods pretty quick but I usually pull them out and wipe them down with WD-40 immediately.
For the block I take it to the car wash and coat it with WD-40 immediately after pulling out of the bay.
I also use a lot of brake parts cleaner and paper towels as the cleaner doesn't leave a residue and the towels don't leave lint.
Re: Cleaning Parts before ASSY [Re: DemonDust] #272017
03/31/09 11:04 AM
03/31/09 11:04 AM
organ
maximum entropy Offline
organ
that's a good first step, and always always use brushes on the block to scrub every nook, passage, and cranny. then i wash it down with solvent, then preservative. the old man always said, if you are not completely soaked, it ain't clean enough. btw, the whole procedure gets repeated after mockup. and again before final assembly. it's the part of engine building i detest most, but it has to be done, and zeal is a requirement.
Re: Cleaning Parts before ASSY [Re: maximum entropy] #272018
03/31/09 05:25 PM
03/31/09 05:25 PM
united kingdom
blown360 Offline
blown360  Offline
united kingdom
At work we steam clean blocks, head, cranks etc making sure we get in every orrifice possible!This does however involve getting drenched throughout!The heat from the steam cleaned parts drys the water real quick.Then before assembly everythings cleaned with lint free cloth and break cleaner.This is however only big diesel engines not race engines but im sure its plenty good enough!Then as said we run the engine up to temp then turn off and replace the oil and filter.These motors might not spin at big revs or make stupid power but they do last over a million miles working days on end!
Re: Cleaning Parts before ASSY [Re: blown360] #272019
03/31/09 06:24 PM
03/31/09 06:24 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
A good test for how clean you think things are is ye olde transmission fluid test. Take a clean white paper towel or equivalent pour clean transmission fluid on the towel and wipe the cylinders. The detergents in tranny fluid will lift off any remaining honing oil and other contaminates. Just try it next time you think you're done cleaning.
