Page 5 of 5 1 2 3 4 5
Re: What to change about my car for n/a [Re: moparx] #2719500
11/26/19 03:54 PM
11/26/19 03:54 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
yes
Originally Posted by moparx
thanks anyway for the response.
is it by chance, aluminum ?
beer
Re: What to change about my car for n/a [Re: Clanton] #2719504
11/26/19 04:03 PM
11/26/19 04:03 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I looked at my 829 lifters and they feel smooth but shoud I put them in a vise w/aluminum jaw and a dial gage?How much play is ok? roller video
update,all of my lifters checked good at .001 play.
Re: What to change about my car for n/a [Re: Clanton] #2719524
11/26/19 05:49 PM
11/26/19 05:49 PM
Sweet5ltr Offline
Sweet5ltr  Offline
Whoa, whats up with this build?
440ci.
Victor Heads
Victor 440 intake manifold
260/269* @ .050 / .650" ish lift solid-roller camshaft
2.5" headers
Open Exhaust
1050 dominator
..13.2's @ 106?
Something is seriously wrong here, you could & should easily have a 120+ MPH build. Going from a 3.73 to 4.10 gear is worth maybe .2-.3 tenths at best and not worth the cost. What brand converter?
You have the foundation for a mid-11 second build in a HEAVY car without boost, you should be making near or over 600 HP on pump gas with a few changes [smaller primary tube headers & 250* / .600" solid-roller camshaft]. Sort out what's wrong with the power N/A before you stick the blower back on it.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
Re: What to change about my car for n/a [Re: Sweet5ltr] #2719528
11/26/19 06:12 PM
11/26/19 06:12 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I agree on the power it should put out and I am working on figuring it out.I have a PTC 9.5 that stalled at 5k with boost.I have the lash .005 tighter testing it and I have in the past at spec lash as you said smoked the tire at will.
ps I was going to set the lask back but ran out of weather to do it.
Re: What to change about my car for n/a [Re: Clanton] #2719530
11/26/19 06:19 PM
11/26/19 06:19 PM
Sweet5ltr Offline
Sweet5ltr  Offline
I just read your engine build post - your heads flow 350 cfm! This should be a nightmare to control even N/A. Something is SERIOUSLY wrong! eek
I would not consider putting the blower back on until you figure this out. Those 2.5" headers need to go - I would look into a 2" primary tube header myself.
Re: What to change about my car for n/a [Re: Sweet5ltr] #2719543
11/26/19 07:52 PM
11/26/19 07:52 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
check out this video at 1:50 or 1:30 and you can see it ran better.
Re: What to change about my car for n/a [Re: Clanton] #2720021
11/28/19 11:48 AM
11/28/19 11:48 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I should check my HS rockers the same way.I am very happy I can run my lifters still
Re: What to change about my car for n/a [Re: Clanton] #2723968
12/14/19 12:07 PM
12/14/19 12:07 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I found an old dyno test with low boost RWHP but with iron heads 280 cfm and .550 sft cam to go from for low boost now and 340cfm heads and .630 cam
ps I am confirming the time slip with low boost yet
Re: What to change about my car for n/a [Re: Clanton] #2723972
12/14/19 12:14 PM
12/14/19 12:14 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Car 1654 on the slip.I think I ran 10.94 with 8lbs.
ps I found some slips that I ran 10.80+ 124
