Re: Moving the Fuse Panel
[Re: QuickDodge]
#2719152
11/25/19 01:02 PM
11/25/19 01:02 PM
Posts: 15,462 Omaha Ne
TJP
Omaha Ne
The wiring harness needs to be replaced. The original harness has been cut and hacked by the previous owner(s). It also appears to have some rodent damage! It is a mess!! I also want to add some extra equipment and circuits. (A/C, sound system, trailer towing harness, etc.)
If the electrical system was good, I'd leave the fuse panel where the factory mounted it! With that info, I'll agree with Topside and suggest American Autowire. Depending on the vehicle they may offer one of their "update series" or you can go with A hiway 15 or 22 series. the 15- 22 series is a 'custom kit" that allows you to do whatever you want. Again depending on the vehicle, If you are using the stock switches etc. that may require you to source the terminals/ connectors. Call them and they can probably supply them as well. We use AA almost exclusively on our non stock applications.
[Re: QuickDodge]
#2719159
11/25/19 01:25 PM
11/25/19 01:25 PM
Posts: 12,238 Looking for a way out of Middl...
IMGTX
I thought about moving my fuse panel until I realized I only replace fuses once or twice every couple of years. A lot of work with very little return. I will in the future repair or replace the fuse box with one that has better contacts. The fuses and contacts get corroded over time and that leads to fuse/wire heat up and failures. I am working on an under hood panel for one of my cars with all the extras in it but leaving the factory fuses and circuits alone. It will have stuff like headlight and fuel pump relays, vacuum pump relays and fuses, etc. I have looked on Amazon and plan on using one like this but with better contacts. I am not endorsing this particular one but I am going with this style. https://www.amazon.com/ONLINE-LED-S...K1/ref=pd_bxgy_img_2/139-8196044-0252245
[Re: Stanton]
#2719281
11/25/19 07:47 PM
11/25/19 07:47 PM
Posts: 2,267 ILLINOIS
volaredon
ILLINOIS
On my son's 89 ramcharger, when we ditched the TBI and went 4 barrel AFB, we wanted to eliminate the fusible links, while at the same time make those circuits remain fused and able to change said fuse instead of cutting out fusible links because fusible link wire is not easily solder-able, neither of us like butt connectors or scotchloks, especially under the hood. So along with retrofitting an 87 harness to the truck, we went scouting the junkyard and found a small under hood fuse box from I forget what, think it was a late 90s zx2 and incorporated that info the factory harness. We were looking for a small fuse box with the"big" fuses. There are enough spots in the fuse box for all of the circuits that we're previously fusible linked plus a few extra spots for future add one like off-road lights, stereo equipment, CB, etc.
[Re: QuickDodge]
#2719423
11/26/19 11:38 AM
11/26/19 11:38 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Using the Eaton Series 1530x-x style fuse/relay box. It uses Metri-Pack 280 terminal connectors, and can come in different configurations. The specific one I have is the series 15305-2. Got it pre-wired with the relays and fuses from Amazon: https://www.amazon.com/gp/product/B01FWILL20/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1But I should have just ordered the box non-wired as I will just use the Metri-pack 280 terminals crimped on the wiring so I don't have to make wire splices. That box series # has the fuses bussed to the main power, and one side of the relays activation coil bussed. I needed 2 relays activated on the high side for the headlights, and the other 3 activated on the low side for cooling fans, horn (or A/C compressor) so I cut the relay side buss, and soldered a ground wire to the upper/end part of the bus. The first 3 relays are still on the stock buss connection that is connected to power through one of the fuses. The 1530x-4 series is the un-bussed box if you need to mix switched and unswitched power, but it will be a few exrea wires ti make the connections to create the power busses.
