Page 23 of 34 1 2 21 22 23 24 25 33 34
Re: Starting to work on the Duster [Re: AndyF] #2714940
11/11/19 08:40 PM
11/11/19 08:40 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Your gonna like those rear tires. They hook real nice and last a long time. What mufflers did you go with Andy?
Re: Starting to work on the Duster [Re: Cab_Burge] #2714950
11/11/19 08:52 PM
11/11/19 08:52 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted by Cab_Burge
Those tips look a lot like the ones I used on my 1966 Coronet up
Could be. They are a B body type tip made for a 3 inch exhaust system.
Re: Starting to work on the Duster [Re: mopar dave] #2714954
11/11/19 08:56 PM
11/11/19 08:56 PM
AndyF Offline OP
AndyF  Offline OP
We used the muffler that fit. There isn't a lot of room for a full 3 inch exhaust under an A body car so there were not many choices. In fact, I think once we laid the whole system out there was only one muffler available that actually fit in the space. I considered cutting the floor to provide more space but the fabricator I was working with said he could make it work. The exhaust system did end up costing a pile of money since it took the fab guy two days and a big box of mandrel bends. But it fits and works and is tucked up out of the way which is what I wanted. I'm not a fan of exhaust systems that hang down below the car.
Re: Starting to work on the Duster [Re: AndyF] #2715810
11/14/19 05:18 PM
11/14/19 05:18 PM
AndyF Offline OP
AndyF  Offline OP
Picked up some nice floor mats with matching B5 script. I haven't decided on carpet yet but I'm sure I'll end up putting carpet in the car if I drive it much. I bet it is going to sound like a thunderstorm on a tin roof every time I drive it.
Re: Starting to work on the Duster [Re: AndyF] #2715812
11/14/19 05:22 PM
11/14/19 05:22 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
TTI makes a turnkey full 3 inch exhaust
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Starting to work on the Duster [Re: B3422W5] #2715880
11/14/19 07:59 PM
11/14/19 07:59 PM
AndyF Offline OP
AndyF  Offline OP
Yeah, I used a TTI turnkey exhaust kit before. Nothing turnkey about it! I knew better this time. It is easier to buy a box of mandrel bends and hire a skilled guy to knock it out than to start off with stuff that doesn't fit but is already welded and coated and has all the brackets in the wrong place.
Re: Starting to work on the Duster [Re: AndyF] #2718216
11/21/19 08:59 PM
11/21/19 08:59 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Wow. Read the enitre thread. Nice work, Andy! Very cool and innovative. Damn nice build!
Wes
"Any fool can know. The point is to understand"
- A. Einstein
Re: Starting to work on the Duster [Re: EvilB1Dart] #2718294
11/22/19 01:34 AM
11/22/19 01:34 AM
AndyF Offline OP
AndyF  Offline OP
Wes
Thanks. Here is a start up video. https://www.youtube.com/watch?v=J2r4PVJXnSk&feature=youtu.be
The engine is running and I've done most of the tuning. Just need to get it road worthy so I can finish up the EFI tuning.
Re: Starting to work on the Duster [Re: AndyF] #2718380
11/22/19 01:18 PM
11/22/19 01:18 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Wes
Wow! Sounds real clean and healthy! Installing the full exhaust system is a nice touch and stealthy. Wheel dyno tuning coming up?
- A. Einstein
Re: Starting to work on the Duster [Re: EvilB1Dart] #2718413
11/22/19 03:10 PM
11/22/19 03:10 PM
AndyF Offline OP
AndyF  Offline OP
Yeah I wanted the exhaust tips coming out the back. It took some work to put a full 3 inch exhaust in there with the narrowed rear end but it all cleared. The key was the fuel cell in the trunk rather than a gas tank hanging down under the floor.
I'm not sure about running it on a chassis dyno. I've never had any luck running automatics on a chassis dyno. The numbers come out weird and it causes confusion. I think I'll just drive it on the street for a while to get comfortable with it and then take it to the track next summer for a few passes.
Re: Starting to work on the Duster [Re: AndyF] #2718420
11/22/19 04:08 PM
11/22/19 04:08 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I agree Andy. Just drive it and have some fun with it. When you think you have a good tune on it, then take it to the track and get a time on it.
Re: Starting to work on the Duster [Re: AndyF] #2718743
11/23/19 08:56 PM
11/23/19 08:56 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Totally understand, been there done that also. Takes time and patience, and then you can still be chasing your tail. Good luck with it. That is definitely a cool project and once sorted out it’s going to be a BEAST and very dependable street car! Best of luck with it.
- A. Einstein
Re: Starting to work on the Duster [Re: AndyF] #2719052
11/25/19 12:35 AM
11/25/19 12:35 AM
AndyF Offline OP
AndyF  Offline OP
Got the dash back from a local body shop. Guy I know there did a little research and came up with a formula for the suede finish on the dash paint. I'd called around a few places and everybody told me that the suede paint wasn't available but he figured it out. Might not be 100% correct but it looks good to me.
Re: Starting to work on the Duster [Re: AndyF] #2719060
11/25/19 01:16 AM
11/25/19 01:16 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Did you make or buy those defrost vent block offs ?
Re: Starting to work on the Duster [Re: demon440] #2719074
11/25/19 05:20 AM
11/25/19 05:20 AM
Germany
stickman60 Offline
stickman60  Offline
Germany
Every detail on the car is sooo beautifully executed. up
Re: Starting to work on the Duster [Re: demon440] #2719085
11/25/19 08:27 AM
11/25/19 08:27 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Those do look nice!
68 Barracuda Formula S 340
Re: Starting to work on the Duster [Re: AndyF] #2719097
11/25/19 10:02 AM
11/25/19 10:02 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Wow, that's actually pretty cool. Details like that can tend to get lost on race cars. Last summer I was at an auto body supply store for what seemed like hours trying to match the original Duracryl lacquer paint on my steering column and what we ultimately came up with wasn't even close. Do you know how they came up with the texture?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Starting to work on the Duster [Re: Bad340fish] #2719135
11/25/19 12:13 PM
11/25/19 12:13 PM
AndyF Offline OP
AndyF  Offline OP
Those do look nice!
I made them. They are laser cut aluminum with pressed in studs with flush heads. Then the nuts attach from below.
Re: Starting to work on the Duster [Re: RMCHRGR] #2719136
11/25/19 12:14 PM
11/25/19 12:14 PM
AndyF Offline OP
AndyF  Offline OP
Here is the paint card. The DX 1999 is a texture additive. I'm not a paint guy so that is the limit of my knowledge.
Re: Starting to work on the Duster [Re: AndyF] #2719141
11/25/19 12:23 PM
11/25/19 12:23 PM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Thanks for posting that dash paint info! I saved that as I will need same on mine.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
