Re: Exhaust Manifold ID?
[Re: 69DodgeCharger]
#271806
03/31/09 01:48 PM
03/31/09 01:48 PM
Posts: 1,719 Middle of the mitten
69DodgeCharger
More stuff from the barn. can anybody ID thiese pieces?
Dr. Side #3751068 P. Side #3614385 Dr. Side #2843956 Dr. Side #3830800 P. Side #4041468 P Side #3751074 Dr. Side #2851861
Anybody? Not sure if these are casting numbers or part numbers?
#271807
03/31/09 09:32 PM
03/31/09 09:32 PM
Posts: 658 WOODGRAINWHEELS.COM Indiana
plumbeeper
Here you go...right from the GG white book...
3751068... LH, 73-74, B body, 400, 440 HP
3614385...no such number, maybe 3614395 LH, 73-74, A body, 318
2843956...no such number, maybe 2843953 RH 67 + 72, A,B,C body, 273, 318 w/heat riser
3830800...RH, T (truck) 400, 440 pick-up
4041468...no such number, maybe 4041463 LH, T (truck) 400, 440 pick-up
3751074...RH, 73, B,C body, 400-2, 440 LP (low power)
2851861...no such number, maybe 2951861 LH, 70-73, C body, 383-400-2, 440 LP/N95
I'm assuming you're getting the numbers right off of the casting which may explain the incorrect (illegible) numbers.
[Re: plumbeeper]
#271808
03/31/09 11:23 PM
03/31/09 11:23 PM
69DodgeCharger
Yes Dave you are totally correct. It is very hard to read the numbers even after wire brushing on some of these manifolds but thanks for your input.
