Re: 1999 dodge ram abs brake problem
[Re: 3wracing]
#2717663
11/19/19 08:19 PM
11/19/19 08:19 PM
Guitar Jones
Sounds like the ABS module/hydraulic assembly is bad. I've seen that before.
[Re: 3wracing]
#2717760
11/20/19 04:28 AM
11/20/19 04:28 AM
Guitar Jones
Tje abs module is where? The other thing is the part with all the0 brake lines?i guess? It's all one unit.
[Re: 3wracing]
#2717810
11/20/19 11:06 AM
11/20/19 11:06 AM
Guitar Jones
I would bleed the unit first one line at a time then bleed the rest of the brakes normally. A pressure bleeder would certainly make it easier.
[Re: 3wracing]
#2717840
11/20/19 01:13 PM
11/20/19 01:13 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
But if I roll up to a stop sign slowly the pedal seems to go to the floor and feels like the antilock is working basically wont stop Any warning lights?
[Re: xs29l9g]
#2717905
11/20/19 07:23 PM
11/20/19 07:23 PM
Posts: 495 northeast pa
3wracing
northeast pa
it pulsates when it does it. leave off brakes step back down its fine. no lights or any thing. if I pull the abs fuse it works fine but then I have to deal with the check engine light.is their a way to check the sensors at the wheels?
[Re: xs29l9g]
#2717906
11/20/19 07:24 PM
11/20/19 07:24 PM
Guitar Jones
A wheel speed sensor would typically set a code.
[Re: 3wracing]
#2718425
11/22/19 05:07 PM
11/22/19 05:07 PM
Posts: 53 massachusetts
xs29l9g
massachusetts
yeah, I would speculate a wheel speed sensor. next step would be identify which one. that will require seein scan data. if you want to guess at it,which im not a fan of, change the one in the rear dif for the rear wheels, I always found this the most common to fail with dodge trucks. sorry didn't see your post that you have pulled the fuse. you can check sensors at the wheels with an ac voltmeter. but would need something to spin the wheel at a consistent low speed....its harder than it sounds and can be tough to detect
