Keith Black blocks rolling out again?
#2717484
11/19/19 12:31 PM
11/19/19 12:31 PM
Posts: 20,199 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Starting to get updates on Facebook about Keith Black blocks rolling out again. Anyone interested may want to check Keith black or Best Machine out on Facebook
Re: Keith Black blocks rolling out again?
[Re: Al_Alguire]
#2717493
11/19/19 12:48 PM
11/19/19 12:48 PM
fast68plymouth
So. Burlington, Vt.
Taking orders now huh? I think Al has had 2 on order for close to 2 years?? The problem didn’t seem to be so much in taking orders........as there was in “filling” orders. Hopefully they get it sorted out.
[Re: Cab_Burge]
#2717593
11/19/19 04:11 PM
11/19/19 04:11 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
If we have the time this week and our prep work is done on the block, will be driving down to FHO Tim Bannings to pick the blocks. yes they are starting to flow. I am talking about the Raise cam Hemi Block,
1971 HEMI E BODY REGISTRY
[Re: sasquatch]
#2717658
11/19/19 08:06 PM
11/19/19 08:06 PM
fast68plymouth
So. Burlington, Vt.
Todd...... do you have any that have been on order for a while thru your shop?
[Re: fast68plymouth]
#2717675
11/19/19 08:56 PM
11/19/19 08:56 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Bill Mitchell posted on face book first four 440 aluminum blocks and off the machines.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2717687
11/19/19 09:14 PM
11/19/19 09:14 PM
Posts: 4,075 Mo.
racerx
Mo.
[Re: mopacltd]
#2717721
11/19/19 10:26 PM
11/19/19 10:26 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Last I looked, it was about $7500 for the block, $1000+ for the head studs, shipping......then, whatever finish machine work is required. Figure between 9- $9500 and closer to 10 if you want bushed lifter bores.
[Re: BradH]
#2717828
11/20/19 12:41 PM
11/20/19 12:41 PM
hemicar1971
Chicago Blackhawks
Have not looked into this for a long time but KB Inc were going to do a GM block also. Hemi Blocks are here not sure of all the variables being cast. Once things settle down on the Hemi Blocks other blocks were going to be looked at and Produced. I will talk to Tim when we are in Bewdley Ontario at his shop. He has to do the lifter bores on two of the blocks and after that we will drive the 30 minutes to pick them up. It has been a long wait for Raise Cam Hemi Blocks, just over 18 months but others might have waited longer for theirs to be cast.
