Struts in a Factory frame rail car???
#271747
03/30/09 05:29 PM
03/30/09 05:29 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
Has any one installed struts on a factory frame rail car. If so, could you post pictures. Finally,what were the results? Were you happy, how did it work?
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
Re: Struts in a Factory frame rail car???
[Re: 408strokerdart]
#271756
04/01/09 04:14 PM
04/01/09 04:14 PM
451Guy
Alberta, Canada
Thanks Again Brian, I have heard that AJE Mopar stuff is not up to snuff! However, it looks like you have got it all worked out and things are working well. I was curious as to how your struts mount at the top? The reason I ask about the brakes is that I have Wilwood's on my car now and if I could save a buck by not having to re buy that stuff I would be happy. Thanks again and it looks Great!
Thanx 451 Guy
