NHRA Pro Stock 500 ci bore, stroke, rod ratio... #2716931
11/17/19 09:54 PM
11/17/19 09:54 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
This seems to have come up on one or two threads recently. Based on some tech articles I found online going back a few years, here are some generalized answers to these questions, NOT based upon current information.
Block deck heights under 9.0"... probably close to 8.6" or 8.7"
Bore sizes 4.70"+
Stroke range 3.5" to 3.6"
Rod ratio 1.6 to 1.7, depending upon how good the heads are (better heads used with shorter rod ratios)
RPMs... before the NHRA mandated the RPM limit (10,500?), sounds like some engines were turning 11K+, maybe even close to 12K
Interesting, but really hard to talk apples-to-apples with the majority of what's being run or built on here.
Google "NHRA Pro Stock bore stroke" and you should see a couple of articles that discussed this stuff.
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: BradH] #2717006
11/18/19 02:54 AM
11/18/19 02:54 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Some Mopar guys seem to really fixate on rod ratios, when in reality, most of the stuff they're running it would make very little difference changing it greatly.
The interesting thing about Pro Stock engines is everyone will be slightly different in it's make up, but they are often making very, very similar power.
Alan Jones
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: BradH] #2717032
11/18/19 08:43 AM
11/18/19 08:43 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
3.6x4.7 is what I have seen. What heads do they use on those engines? Thanks for posting Brad.
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: LA360] #2717052
11/18/19 09:33 AM
11/18/19 09:33 AM
BradH Offline OP
BradH  Offline OP
The interview w/ the Elite Motors engine guy has some interesting comments re rod ratio and head choice.
At the level those engines are, he said they were using upwards of 1.8 RR before the heads had evolved to where they could "keep up" w/ the faster acceleration from TDC of the lower RRs. As the heads continued to improve, they could lower the RR because the better heads weren't the restriction. No mention, at least in that context, of the downside of increased piston-to-wall friction w/ the increased angularity of the rods. However, given their pistons probably look like hockey pucks with valve reliefs, there would be less skirt surface area to be pushed against the cylinder wall, too.
At least this is in sync w/ the general idea I've heard that a longer RR is better when the heads are limited.
The WJ article I read was older, but confirmed some of the "where we came from" context of the later article.
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: BradH] #2717142
11/18/19 12:38 PM
11/18/19 12:38 PM
Washington
madscientist Offline
Washington
I read an article last night I can't find today about a big (900 plus CID IIRC) Sonny Leonard engine and it had over an 8 inch long Rod in it and that was near a 2:1 ratio.
I've said it many times, had a pretty heated discussion with a well known PS engine builder about this very thing. Rod to stroke ratio makes a BIG difference when you are induction limited. I don't even know why that is questioned.
And the FACT is virtually every Chrylser based engine we discuss here is induction limited.
Talking about Rod ratio in a PS is a different discussion because the induction system is more than capable of feeding a paultry 500 CID at 10,500 RPM.
To make the blanket statement that Rod to stroke ratio doesn't matter is rediculous when the entire combination isn't considered.
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: BradH] #2717181
11/18/19 01:54 PM
11/18/19 01:54 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
That was my next question, what type of pistons are used in PS.
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: madscientist] #2717189
11/18/19 02:03 PM
11/18/19 02:03 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Fair enough but most of these discussions on rod ratios here revolve more around piston side loading concerns even tho every BBC on the planet has what many here consider an unacceptable ratio.
Kevin
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: mopar dave] #2717190
11/18/19 02:03 PM
11/18/19 02:03 PM
The best ones they can get that day work grin
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: Cab_Burge] #2717198
11/18/19 02:47 PM
11/18/19 02:47 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Ok, but what I ment was short skirt, long skirt and what kind of pin height?
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: mopar dave] #2717202
11/18/19 02:54 PM
11/18/19 02:54 PM
BradH Offline OP
BradH  Offline OP
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: BradH] #2717207
11/18/19 03:14 PM
11/18/19 03:14 PM
That article is over 4 yrs. old, I wonder what the hot parts are today with EFI?
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: BradH] #2717211
11/18/19 03:17 PM
11/18/19 03:17 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Looks like it uses a piston-guided connecting rod set up.
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: BradH] #2717230
11/18/19 04:06 PM
11/18/19 04:06 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yeah, those are short.
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: mopar dave] #2717260
11/18/19 05:44 PM
11/18/19 05:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
There is a Pro Stock Tech thread in the Naturally Aspirated section over on Yellowbullet. Nick Ferri posts over there quite a bit and is surprisingly forthcoming with answers to questions and what goes into those engines.
'63 Dodge 330
11.19 @ 121 mph
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: GY3] #2717275
11/18/19 06:34 PM
11/18/19 06:34 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Thanks, I'll check that out . Brad's link was very informative
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: LA360] #2717807
11/20/19 11:01 AM
11/20/19 11:01 AM
BradH Offline OP
BradH  Offline OP
Piston compression height calcs for 10.700 RB W/ zero deck height:
3.750 stroke w/ 6.760 rod = 2.065
RR = 1.80
3.910 stroke w/ 7.100 rod = 1.645
RR = 1.82
4.150 stroke w/ 6.760 rod = 1.865
RR = 1.63
4.150 stroke w/ 7.100 rod = 1.525
RR = 1.71
4.250 stroke w/ 7.100 rod = 1.475
RR = 1.67
Not "fixated", just observant... scope
Re: NHRA Pro Stock 500 ci bore, stroke, rod ratio... [Re: GY3] #2718379
11/22/19 01:17 PM
11/22/19 01:17 PM
texas
thewolf1970 Offline
thewolf1970  Offline
texas
Nick is one of the most brilliant engine builders you will meet or ever know. Man has taught me stuff you would never think of.
