Re: Source for correct factory U Bolts.
[Re: floyd]
#2716553
11/16/19 09:43 PM
11/16/19 09:43 PM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
I’m pretty sure Frank Badalson has them. Not sure who that is (at least I think I don’t know), do you have a link to him by chance? Thanks in advance.
[Re: migsBIG]
#2716568
11/16/19 10:30 PM
11/16/19 10:30 PM
Posts: 13,601 md
mopars4ever
md
[Re: floyd]
#2716595
11/17/19 12:25 AM
11/17/19 12:25 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
The main source is amkproducts.com. AFAIK everybody else re-selling AMK by buying in volume with volume discounts, maybe, and re-selling with some markup. Might be best to check the main source's price first, keeping in mind they do have a $30 minimum order. https://www.amkproducts.com/bulk-fasteners-listing/?codeforlookup=7060and scroll to bottom. These parts are correct to the original Chry part numbers. $28/pair + $10 ship = $40 due to min order. This is without the nuts, which are also available elsewhere on the web site. For nuts, go to https://www.amkproducts.com/ > catalogs > hex nuts.
[Re: kentj340]
#2716618
11/17/19 08:11 AM
11/17/19 08:11 AM
Posts: 4,922 new berlin wisconsin
Mr T2U
i have a mint set from a E-body that have been on the shelf for about 30 years. i think i am missing 1 nut. if they fit in a small flat rate box i will sell for $20 shipped. i have to dig them out for pics if you want them.
perception is 90% of reality
[Re: migsBIG]
#2716659
11/17/19 11:45 AM
11/17/19 11:45 AM
Posts: 12,138 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Went to pull the rearend out of my 72' Charger and they were soo rusty, even power tools could not remove the bolts, so they had to be cut off the rearend. Anybody still carry correct U bolts and nuts for that model? Also what color/paint or are they left bare? It's for an 8 3/4 with swaybar. It's a little late now, but about the only way to get the nuts off the U bolts is with heat. And a lot of it. Wire brush or chase the exposed threads as much as possible, cherry up the nuts and they will come off. Frankly, without an oxy/acetylene torch set, I couldn't work on my old Mopars.
Master, again and still
[Re: DaveRS23]
#2716885
11/17/19 08:48 PM
11/17/19 08:48 PM
migsBIG
San Jose,CA
Went to pull the rearend out of my 72' Charger and they were soo rusty, even power tools could not remove the bolts, so they had to be cut off the rearend. Anybody still carry correct U bolts and nuts for that model? Also what color/paint or are they left bare? It's for an 8 3/4 with swaybar. It's a little late now, but about the only way to get the nuts off the U bolts is with heat. And a lot of it. Wire brush or chase the exposed threads as much as possible, cherry up the nuts and they will come off. Frankly, without an oxy/acetylene torch set, I couldn't work on my old Mopars. Yes, we used two portable torches til orange and they would.not budge. Air gun was industrial and could only remove 5 of the nuts.
[Re: A727Tflite]
#2717051
11/18/19 09:31 AM
11/18/19 09:31 AM
Posts: 4,115 MD
floyd
MD
[Re: migsBIG]
#2717058
11/18/19 09:43 AM
11/18/19 09:43 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Went to pull the rearend out of my 72' Charger and they were soo rusty, even power tools could not remove the bolts, so they had to be cut off the rearend. Anybody still carry correct U bolts and nuts for that model? Also what color/paint or are they left bare? It's for an 8 3/4 with swaybar. It's a little late now, but about the only way to get the nuts off the U bolts is with heat. And a lot of it. Wire brush or chase the exposed threads as much as possible, cherry up the nuts and they will come off. Frankly, without an oxy/acetylene torch set, I couldn't work on my old Mopars. Yes, we used two portable torches til orange and they would.not budge. Air gun was industrial and could only remove 5 of the nuts. Holy crap!
[Re: migsBIG]
#2717064
11/18/19 09:55 AM
11/18/19 09:55 AM
Posts: 704 WV
Little Detroit
WV
largest selection of OEM correct USA made fasteners in stock Little Detroit Restorations 304 797 0607 web site littledetroitrestorations@hotmail.com
[Re: floyd]
#2717290
11/18/19 07:33 PM
11/18/19 07:33 PM
Mr T2U
they may be NOS but the nuts are definitely not assembly line correct. the correct nuts have indentations on them and they don't have washers made with the nuts.. here is a pic of the ones i remove in the early 80's from a car. they have been in storage since removal. look closely and you can see the indentations on the nuts.
[Re: mopars4ever]
#2717769
11/20/19 07:34 AM
11/20/19 07:34 AM
Mr T2U
you could be right on the silver vs black. if i remember correctly my U bolts are from my first rebuild project. i bought 3 totaled cuda's in 1975 for the enormous sum of $250. i then used parts from 1 car to fix the other 2. after they were repaired i think i sold them for $1500 each. the U bolts were in a box of parts i found in storage. things might have been mixed up over the years, maybe someone worked on the car before i bought it. all i know is the cross hatch pattern on the inside of 1 U bolt is different than the other 3. when i found them all of the U bolts and nuts were in 1 plastic bag just as i removed them in 1975.
