Best Options for Replacement Wiring Harness #271485
03/30/09 01:24 PM
03/30/09 01:24 PM
Kentucky, USA
RoadrunnerCN Offline OP
Kentucky, USA
What's the best option to replace my 1970 Plymouth Satellite wiring harness? I located a classic car "generic" 12 circuit one, but wondered if I should get one made just for my car. It was an A/C car, but I removed all the A/C stuff. Just want the basics. Any suggestions? Quality at a decent price is what I'm looking for. Thanks. Chris.
Re: Best Options for Replacement Wiring Harness [Re: RoadrunnerCN] #271486
03/30/09 01:45 PM
03/30/09 01:45 PM
None
71rm23 Offline
71rm23  Offline
None
its being talked about right now as I type..In the resto pages
https://board.moparts.org/ubbthreads/show...e=0#Post5124370
Re: Best Options for Replacement Wiring Harness [Re: RoadrunnerCN] #271487
03/30/09 02:24 PM
03/30/09 02:24 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
M&H wiring; buy it at Year One. Not the cheapest option, but this isn't an area I would scrimp on.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Best Options for Replacement Wiring Harness [Re: RoadrunnerCN] #271488
03/30/09 02:27 PM
03/30/09 02:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You can try 'bay. Even a used unit might be of use. Of course new is nice.. but pricey. which harness do you want to replace? Dash?
Re: Best Options for Replacement Wiring Harness [Re: Mr.Yuck] #271489
03/30/09 03:53 PM
03/30/09 03:53 PM
Kentucky, USA
Kentucky, USA
Yes, the dash harness. I won't be needing the A/C connections, but the connections for the heater, fan, dash lights, etc. are what I need.
Re: Best Options for Replacement Wiring Harness [Re: DPelletier] #271490
03/30/09 05:01 PM
03/30/09 05:01 PM
None
71rm23 Offline
71rm23  Offline
None
Re: Best Options for Replacement Wiring Harness [Re: RoadrunnerCN] #271491
03/30/09 06:58 PM
03/30/09 06:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Doesn't matter you get all the wires anyway. Not an easy swap either unless you have the dash completly apart and the seats out of the car.
Re: Best Options for Replacement Wiring Harness [Re: Mr.Yuck] #271492
03/31/09 12:56 PM
03/31/09 12:56 PM
Kentucky, USA
Kentucky, USA
Thanks...dash is coming out. Seats too.
Re: Best Options for Replacement Wiring Harness [Re: RoadrunnerCN] #271493
03/31/09 01:10 PM
03/31/09 01:10 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
before you spend $$$ on a new one you could test your old one wire by wire...ohm test it. Unless it' all hacked up or burned. You might be suprised. I was going to buy a new kick panel to rear harness and headlight harness. I cleaned al the terminals up and tested each wire. They were all good. So I saved a few $$$ on that.
Re: Best Options for Replacement Wiring Harness [Re: Mr.Yuck] #271494
04/01/09 09:20 AM
04/01/09 09:20 AM
Kentucky, USA
Kentucky, USA
Good suggestion. I have almost all the outer stuff off the dash and a new used clean dash ready to go in, but once I get the whole thing out I'll better be able to see what the old harness looks like. A volt/ohm meter is in my bag of tools and I wasn't even thinking of using it. Duh on my part. You probably saved me a bundle. Probably was obvious, but you guys know that when a big project is in front of you a lot is going through your mind. Thanks. Chris.
Re: Best Options for Replacement Wiring Harness [Re: RoadrunnerCN] #271495
04/01/09 09:39 AM
04/01/09 09:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
don't forget to clean the bulk head. I went to Radio Shack and got a can of their cleaner/lube. That stuff works great.
