Re: Oil Leaking from Oil Filter area
[Re: Warrant_Officer]
#271474
03/30/09 01:15 PM
03/30/09 01:15 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
does it have a 90 degree adaptor?
did you check to see if there was 2 gaskets under the filter? needs only one gasket, sometimes the old one gets stuck on there and doesn't come off with the filter.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
#271479
03/30/09 04:18 PM
03/30/09 04:18 PM
RapidRobert
I'd get the fel pro outer ring gasket as it's thicker than the outer ring gasket in the MP 3 piece kit. Clean the block recess/flat plate good, use some sealer on the above gasket & I think you'll be OK.
