Please help me read my spark plug #2710191
10/26/19 04:09 PM
10/26/19 04:09 PM
Aurora, CO
jbeintherockies Offline OP
Aurora, CO
Hi,
help
I pulled my #1 plug from my stroked 340. I have not learned the art of reading plugs. The porcelain appears to have chipped off on one side of the plug. I think that is indicative of detonation; but I haven't heard any rattle or ping (means nothing). The plugs are Autolite 64's.
https://drive.google.com/file/d/15R7gOsiHDfcLlziLcsJYAa1f0qF0jXW8/view?usp=sharing
https://drive.google.com/file/d/15X6JF_Ls3pw8PNM9XuHqk_3mki3e09HF/view?usp=sharing
https://drive.google.com/file/d/15WXBwJnwwYXbtvrHfXDCLO8ZvD7N-2rm/view?usp=sharing
TYiA!
beer
Re: Please help me read my spark plug [Re: jbeintherockies] #2710211
10/26/19 05:58 PM
10/26/19 05:58 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Looks more like some nasty additives coating your plugs and that;s what's chipping off. What are you running for fuel?
Re: Please help me read my spark plug [Re: Sniper] #2710219
10/26/19 06:25 PM
10/26/19 06:25 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
What fuel are you running ?
Re: Please help me read my spark plug [Re: jbeintherockies] #2710292
10/27/19 01:24 AM
10/27/19 01:24 AM
Cab_Burge Online work
Cab_Burge  Online Work
The porclyn is NOT chipping off, it is chemical deposits from combustion that you are seeing chipping off up
What type of heads (aluminum or iron)and compression are you running?
You might want to try a #65 plug in your motor to see if that hotter plug will burn hot enough to prevent those deposits scope twocents
Re: Please help me read my spark plug [Re: Sniper] #2710388
10/27/19 02:34 PM
10/27/19 02:34 PM
Aurora, CO
Aurora, CO
Hello,
I have been using Exxon/Mobil Synergy Supreme premium gasoline mixed with about 5 gallons of Sunoco 260 (100 octane).
https://www.exxon.com/en/synergy-supreme-plus
https://www.sunocoracefuels.com/fuel/260-gt
Adding the 260 really helps with fuel boil.
About the car, '68 Barracuda FB Formula S, 3.91's, 5 speed manual, DLI ported X heads, M1 intake, holley carb, mech roller cam (about 248@50), about 9.7:1 compression ratio, bored and stroked to about 386ci. Timing is 22 degrees initial, 37 total all in at 2500. Vacuum advance adds about 8 degrees of advance. This engine likes a lot of advance, meaning I could probably go with a little more initial and total (2-3 degrees). Maybe it wants more timing to burn off some of the deposits?
Cab's suggestion of a hotter plug is interesting; I could give it a try and listen carefully for ping/rattle.
If you need any additional info, please ask.
What pump gas are you guys running in your cruisers with carbs?
Re: Please help me read my spark plug [Re: jbeintherockies] #2710479
10/27/19 09:29 PM
10/27/19 09:29 PM
The race fuel is making the deposits on your plugs, at that compression ratio and any altitude above 4500 you don't need any fuel additive or race fuels twocents
Based on how much total timing your running I'm assuming your above 5000 FT altitude, correct?
On your deal I would change to the #65 Autolites with no other tuning changes other than dropping the race gas to your tank scope twocents
I use to help several NHRA stock class racers that ran 340 motors, one ended up setting the E/SA record that stood for two years, later on he held the C/SA record with a Challenger I sold him that he made into a 340 6 pack T/A clone car, that car was a rocket ship up None of those Stocker motors, 1970 4 barrel, 1970 six pack and the1971 340 four barrel motors like more than 33 degree total at the track or on the engine dyno under 4000 Ft altitude in SO CA shruggy
IHTHs thumbs
Re: Please help me read my spark plug [Re: jbeintherockies] #2714612
11/10/19 07:24 PM
11/10/19 07:24 PM
Aurora, CO
Aurora, CO
I think this plug has oil contamination on it, as indicated by the shiny and crusty deposits; please confirm:
https://drive.google.com/file/d/17cxPxlG9T3D6jL7VeWem-VuHjm-Gmbta/view?usp=sharing
Re: Please help me read my spark plug [Re: jbeintherockies] #2714652
11/10/19 09:32 PM
11/10/19 09:32 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Maybe, what does it smell like? oil or gas? If it's still looking that that the next morning then yeah I'd say it was oil
Re: Please help me read my spark plug [Re: jbeintherockies] #2714698
11/11/19 02:26 AM
11/11/19 02:26 AM
Man, that dude is nasty, fix the problems and that motor should wake up a bunch of power grin
It looks like oil and maybe to rich also. have you done a leak down or compression test on the motor? If so what where the results? If not try and do that next wrench up
