Help With 904 Converter #2713144
11/05/19 08:30 PM
11/05/19 08:30 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
I have a small hub 904 Converter ( 1966 ) that I want to put into a 1989 , 318 engine ,so I need the spacer to make it work , I just can't find a vendor ,they may not be available anymore , but if there is a source help would be grateful.
Re: Help With 904 Converter [Re: 426lloyd] #2713198
11/05/19 10:34 PM
11/05/19 10:34 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Charlie Schmid in Florida sells them. If you want his number shoot me a PM.
Re: Help With 904 Converter [Re: 426lloyd] #2713202
11/05/19 11:01 PM
11/05/19 11:01 PM
Texas
GTS440 Offline
GTS440  Offline
Texas
I put a 67 225 in a 69 & the crankshaft hole was a different size & i believe the spline count for the tranny was also different. Had a converter converter shop put the 69 guts into the 67 converter. Make sure the spline count is the same before you go to any other trouble.
Re: Help With 904 Converter [Re: slantzilla] #2713475
11/06/19 07:20 PM
11/06/19 07:20 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Thanks I will contact Charlie
