Re: 906 Heads True Combustion chamber cc??
[Re: momopar]
#527595
11/16/09 10:52 AM
11/16/09 10:52 AM
Posts: 2,826 NY usa
540challenger
NY usa
Isn't the "blueprint" for a 906 79.5cc?
I think the guy putting this together went by blue-print spec instead of actually CCing the heads. The blue pritned numbers are all fudged numbers.
[Re: lewtot184]
#527596
11/16/09 10:53 AM
11/16/09 10:53 AM
Posts: 2,826 NY usa
540challenger
NY usa
an unmilled head will vary between 88cc-90cc, usually closer to 88cc.
thank you
[Re: momopar]
#527597
11/16/09 11:51 AM
11/16/09 11:51 AM
Posts: 74,992 U.S.S.A.
JohnRR
U.S.S.A.
NO ,That is the NHRA spec which doesn't remotely resemble actual , which is usually 90 cc , I have a bunch and never seen any under 90cc that haven't been decked.
If the shop cc'd them and they are 78 they have been decked , A LOT .
[Re: Dodgem]
#2712254
11/02/19 10:06 PM
11/02/19 10:06 PM
Posts: 9,991 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The numbers are not fudged they were designed to be 78.5 (by the blue prints) but any I ever checked were 86 to 88. I milled a set to 63 cc (about .105 to .110 off) turned them into closed chamber!! They worked good for a few years till one cracked back in the intake port where the porting had made it thin! <img src="/ubbthreads/images/graemlins/shruggy.gif" alt="" /> I had a set cut like that. Under a black light they looked like a lit christmas tree after a few seasons!
