906 Heads True Combustion chamber cc?? #527592
11/16/09 10:37 AM
11/16/09 10:37 AM
NY usa
540challenger Offline OP
NY usa
Has anyone CCed the combustaion chamber on Big block 906 heads. I have a buddy geting a motor built and the guy puting the motor together for him said that they CCed at 78 CC and they were never milled This doesn't seem right to me. Thanks for the help/
Re: 906 Heads True Combustion chamber cc?? [Re: 540challenger] #527593
11/16/09 10:44 AM
11/16/09 10:44 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
an unmilled head will vary between 88cc-90cc, usually closer to 88cc.
Re: 906 Heads True Combustion chamber cc?? [Re: lewtot184] #527594
11/16/09 10:49 AM
11/16/09 10:49 AM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
Isn't the "blueprint" for a 906 79.5cc?
Re: 906 Heads True Combustion chamber cc?? [Re: momopar] #527595
11/16/09 10:52 AM
11/16/09 10:52 AM
NY usa
NY usa
I think the guy putting this together went by blue-print spec instead of actually CCing the heads. The blue pritned numbers are all fudged numbers.
Re: 906 Heads True Combustion chamber cc?? [Re: lewtot184] #527596
11/16/09 10:53 AM
11/16/09 10:53 AM
NY usa
NY usa
thank you
Re: 906 Heads True Combustion chamber cc?? [Re: momopar] #527597
11/16/09 11:51 AM
11/16/09 11:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
NO ,That is the NHRA spec which doesn't remotely resemble actual , which is usually 90 cc , I have a bunch and never seen any under 90cc that haven't been decked.
If the shop cc'd them and they are 78 they have been decked , A LOT .
Re: 906 Heads True Combustion chamber cc?? [Re: 540challenger] #527598
11/16/09 11:51 AM
11/16/09 11:51 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The numbers are not fudged they were designed to be 78.5 (by the blue prints) but any I ever checked were 86 to 88. I milled a set to 63 cc (about .105 to .110 off) turned them into closed chamber!! They worked good for a few years till one cracked back in the intake port where the porting had made it thin!
Re: 906 Heads True Combustion chamber cc?? [Re: 540challenger] #527599
11/16/09 11:52 AM
11/16/09 11:52 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I got 92s on my 452s. Specs on websites states 84... GO FIGURE
Re: 906 Heads True Combustion chamber cc?? [Re: NachoRT74] #527600
11/16/09 11:55 AM
11/16/09 11:55 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea the 452's were mostly 90/92 as cast!
Re: 906 Heads True Combustion chamber cc?? [Re: Dodgem] #527601
11/16/09 12:41 PM
11/16/09 12:41 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
90-92 as cast.
Re: 906 Heads True Combustion chamber cc?? [Re: moper] #527602
11/16/09 01:50 PM
11/16/09 01:50 PM
Virginia
67 GTX Offline
67 GTX  Offline
Virginia
My 906 heads milled 0.010 measured to be 84 cc.
Re: 906 Heads True Combustion chamber cc?? [Re: 67 GTX] #527603
11/16/09 02:47 PM
11/16/09 02:47 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i have a couple sets of 915 close chamber heads the one i used on my RR cc at 80cc with the small exh, most opens were 90 + then add a couple valve jobs where the valve sinks add more cc's. If you have replaced the valves with ones that are not concaved like the factory ones then you could cut down the cc's buy a bit.
Re: 906 Heads True Combustion chamber cc?? [Re: ademon] #527604
11/16/09 03:23 PM
11/16/09 03:23 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I had mine cc'd and it came out to 93+cc
Re: 906 Heads True Combustion chamber cc?? [Re: PAINT IT BLACK] #527605
11/16/09 04:14 PM
11/16/09 04:14 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I CC'd a set & they were 91.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 906 Heads True Combustion chamber cc?? [Re: Dodgem] #2712254
11/02/19 10:06 PM
11/02/19 10:06 PM
gregsdart Offline
gregsdart  Offline
Originally Posted by Dodgem
The numbers are not fudged they were designed to be 78.5 (by the blue prints) but any I ever checked were 86 to 88. I milled a set to 63 cc (about .105 to .110 off) turned them into closed chamber!! They worked good for a few years till one cracked back in the intake port where the porting had made it thin! <img src="/ubbthreads/images/graemlins/shruggy.gif" alt="" />
I had a set cut like that. Under a black light they looked like a lit christmas tree after a few seasons!
Re: 906 Heads True Combustion chamber cc?? [Re: gregsdart] #2712255
11/02/19 10:08 PM
11/02/19 10:08 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
do you realize this ia a ten year old thread?
Re: 906 Heads True Combustion chamber cc?? [Re: 540challenger] #2712271
11/02/19 10:51 PM
11/02/19 10:51 PM
Every stock 906 I've check had 90+ CC, every one of many, the chambers will vary from 2.0 to 4.5 CC on the same head also puke
