P2146 Fault Code #2711542
10/31/19 10:34 AM
10/31/19 10:34 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
2007 Dodge CTD, had a short stumble several weeks ago, CEL on, lasted about 30 second. Last night same thing. I have
a Edge with attitude, Im thinking it’s that to be the cause of the problem. Anyone else have or had this issue?
Abe Lincoln
Re: P2146 Fault Code [Re: dart4forte] #2712021
11/02/19 06:32 AM
11/02/19 06:32 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Injector
Re: P2146 Fault Code [Re: J_BODY] #2712343
11/03/19 11:09 AM
11/03/19 11:09 AM
Mesa, Arizona
Mesa, Arizona
Originally Posted by J_BODY
Injector
Yes, banks 1-3. Had a guy help me with it. Disconnected the harness on banks 1-3, reconnected and switched the Edge to the stock setting. That was several days ago.. After a week he said to go thru the different settings, mileage and tow to see if they are the problem. If not and it doesn’t display the previous symptom it was probably a loose 1-3 bank coupler.
Abe Lincoln
