Re: a body fuel sending unit
[Re: surfman]
#2711593
10/31/19 12:27 PM
10/31/19 12:27 PM
RapidRobert
The dealer here had (may still) have a parts locating service nationwide thru Chrysler. Ebay might be a source & you might google chrysler NOS parts (not sure what wording to use) or out an ad in here & FABO & a good used one might be a solution
[Re: surfman]
#2711601
10/31/19 12:51 PM
10/31/19 12:51 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Dad needed a unit for his 1970 Pontiac, those are very unusual units, made of unobtainium. We finally resorted to Bob's Speedometer Shop for a rebuild. https://www.bobsspeedometer.com/1/120/index.asp A bit spendy but when there's nothing else available... Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2711613
10/31/19 01:29 PM
10/31/19 01:29 PM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
mine finally failed after 44 years Thanks Soak it in EvapoRust to clean it up. Then pop off the cover and see what it looks like inside. There is a little "tab" inside that rides on the resistor. It could be broken or just worn and not making contact any more. You might be able to fix it.
[Re: surfman]
#2712046
11/02/19 10:22 AM
11/02/19 10:22 AM
Posts: 5,444 So Cal
Sinitro
So Cal
Check out Manicini Racing.... They carry some nice replacements for A-bodies.. Not NOS but good quality.. Just my $0.02...
